02-21-2007, 05:36 PM #1Junior Member
- Sep 2006
- Scranton
Black- 1999 Z28
Electrical/charging problem problem
I am having a weird electrical prob on my 1999 Camaro Z28
Sometime my alternator does not charge.
My battery drains after a few days of sitting.
when I turn the car on the gauges dont work for 30 seconds and the odometer resets. This usually happens when it is cold.
I have already replaced the alternator and battery.
The new alternator seems to help somewhat the car charges better but not 100%
Could this be a bad body computer which controls my odometer and guages?
02-21-2007, 05:55 PM #2Member
- Oct 2006
- Oklahoma City
00 LS1, WS6, V8 Gremlin- 96 & 98 GTPs, 64 'Cuda
Find out what's draining your battery first.
Here's an easy way to figure it out.
Get or rig up some sort of 12V test light. You can usually buy them for $1 at a discount tool place or use any 12 volt bulb that you can atach wires to.
Get a couple of big clip leads from Radio Shack.
Remove your + battery cable and hook the light between the + battery terminal and the + battery cable. If anything's drawing power the light will come on.
There are normal battery drains such as the clock in your radio and a bit from the various computers but it shouldn't light up very brightly.
Next, start removing fuses one at a time, if the light dims quite a bit after removing one that shouldn't be drawing power (example - brake lights) you've found the drain.
Also - don't rule out the new alternator. Try disconnecting it as it shouldn't draw anything by itself.
02-22-2007, 10:21 PM #3
02-22-2007, 11:59 PM #4Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
And make sure you know your radio code before disconnecting the battery if you have the theftlock set
02-23-2007, 05:59 AM #5Member
- Oct 2006
- Oklahoma City
Electrical problems beyond the obvious tend to send any tech up the wall.
There are usually simple solutions but tracing down an intermittent short can be difficult if you don't have a $3000 piece of test equipment that will localize it to inches.
We're open to challenges, hit us with your worst and we'll try to work you through it.
Help: Electrical problem? Please help.
By mammoth713 in forum General HelpReplies: 19Last Post: 05-10-2010, 10:15 AM -
problem with battery charging
By stangslayer98 in forum External EngineReplies: 8Last Post: 07-06-2009, 07:01 PM -
99 Trans Am Battery/Charging System Problem
By 1999TransAmWS6 in forum Firebird / WS6Replies: 2Last Post: 10-13-2007, 05:06 PM -
Charging Problem
By Barry00Z in forum General HelpReplies: 6Last Post: 09-11-2007, 10:43 AM -
Possible Charging Problem???
By Joe K. 99 Zeee!! in forum General HelpReplies: 7Last Post: 07-09-2006, 06:04 AM
