Results 1 to 3 of 3
10-13-2007, 03:57 PM #1
99 Trans Am Battery/Charging System Problem
Hey everyone,
I'm having a problem with my 99 Trans Am. It just started about 2 weeks ago and no changes have been made before it began happening. If my car sits for 8 hours or more, the battery is too drained to start the car. The battery is about 1 year old. I also replaced the alternator last week. All connections look good. I took it to 2 different places to have a system check. Alternator is 14.0 volts......battery tests good......system draw with car off passes at about 0.1amps. I do get an occasion DTC code of
P1637 Generator L-Terminal Circuit.
Any help is greatly appreciated!
Thanks in advance.
10-13-2007, 04:36 PM #2
wow that is a prob...if it passes the amp test the only thing i could think of is bad battery it does happen and about the code i have the same code in mine it doesnt throw the SES light but its in there im not much worried about it yet ...good luck man
10-13-2007, 05:06 PM #3
Yeah, it's pretty frustrating. I'm still thinking it's the battery too. I have a 95 Trans Am with the same battery and about the same age so I swapped them tonight to see if the problem stays with the car or the battery. Thanks for your help.
98 z/28 charging battery
By LETHALxLS1 in forum Camaro / SSReplies: 16Last Post: 03-04-2013, 12:32 AM -
Question: Charging the Battery Key
By The Silver Goat in forum GTOReplies: 8Last Post: 02-07-2010, 06:27 PM -
problem with battery charging
By stangslayer98 in forum External EngineReplies: 8Last Post: 07-06-2009, 07:01 PM -
Charging the battery
By rajiv1998 in forum General HelpReplies: 17Last Post: 05-02-2008, 09:41 PM -
battery not charging
By Unfrozn in forum General HelpReplies: 6Last Post: 05-10-2007, 08:34 AM
