    Member The Silver Goat's Avatar
    Dearborn Michigan
    Qucik Silver Metalic
    2004 GTO - M6
    Charging the Battery Key
    I read in a thread somewhere placing the key in the iginition charges the battery in the key?
    True or False?
    Subscribed. I have never heard of such a thing so this interests me.
    Retired Outlaw Sum Bitch
    False
    Member Skippy's Avatar
    Oct 2009
    Perkins, OK
    04 Pontiac GTO
    How do you change the battery on one of our keys? Or can you?
    Ashes to ashes and dust to dust, if it wasn't for fords our tools would rust
    North Jersey
    Phantom Black Metallic
    2004 GTO M6
    From what I have heard, ya can't change the battery. You have to buy a new key from either the dealer or eBay and you have to go through all sorts of reset sequences to setup the key for your car.
    Oct 2009
    Perkins, OK
    04 Pontiac GTO
    That blows. Any idea how long the battery lasts. Sometimes my car doesnt respond unless im really close to it and other times itll work from 60 yards away.
    North Jersey
    2004 GTO M6
    No clue as far as I know. I alternate between keys to keep from using up the batteries every once in a while. If you have two keys, alternate.
    Nebraska
    Purple
    2004 GTO
    I tried 2 get battery replaced they soddered they battery in so u have to buy a new one
    Member PatrizioD's Avatar
    The Anus of America; RI
    Nero
    2006 gto
    I'd imagine that if you hooked up an alternate power source to the key's main board, you could de-solder the battery and put a new one in. The trick would be keeping a continuous power flow so the key doesnt reset itself (if that is indeed what it does). Also, if the key battery dies before you switch it, it might defeat the whole process.
    Just grab a key off eBay or something. Do any of the fancy remote fobs work with our cars? You'd still need the key to drive*, but at least you'd have another fob to control the doors...just a thought.
    *Will a dead battery in a key prevent it from starting the car???
    Anyone without a gun and a knife and a handkerchief and a chapstick get the F%$# out of here!
  1. 98 z/28 charging battery
    By LETHALxLS1 in forum Camaro / SS
    Last Post: 03-04-2013, 12:32 AM
  2. problem with battery charging
    By stangslayer98 in forum External Engine
    Last Post: 07-06-2009, 07:01 PM
  3. Charging the battery
    By rajiv1998 in forum General Help
    Last Post: 05-02-2008, 09:41 PM
  4. alternator not charging battery...HELP
    By Unfrozn in forum External Engine
    Last Post: 11-05-2007, 06:32 PM
  5. battery not charging
    By Unfrozn in forum General Help
    Last Post: 05-10-2007, 08:34 AM
