Thread: I put a water pump on now.......
03-17-2009, 05:31 AM #1Junior Member
- Dec 2008
- VA BEACH, VA
Black- 99 Camaro
I have a viberation in park and neutral from 600 rpms to 1,000rpms then it is gone. If i put it in drive it is not bad at all in fact you can hardly tell. It goes away after you get over a grand in rpms. and it is at its worse the closer you get to 1000 rpms. i thought it was the balancer because my old one wobbled a little bit but i replaced that and it still wobbles a little like before
Anybody have a clue whats wrong? All the sensors are plugged back in, lines are hooked back up, and the pulleys and belts seem to be just fine as well.
03-17-2009, 07:46 AM #2
Umm How much is a little wobble?
03-17-2009, 07:50 AM #3Member
- Feb 2008
- NEW JERSEY
PEWTER- 2001 TRANS AM WS6
Bent crank?
03-17-2009, 08:09 AM #4Junior Member
- Dec 2008
- VA BEACH, VA
Black- 99 Camaro
not alot at all...... had some people look at it and said its fine. but the viberation wasnt there until i did the water pump
03-17-2009, 08:45 AM #5
You could have a bad water pump -- especially if it is a remanufactured one. Had the same thing happen in a Trailblazer last week. Vibration turned out to be a bad water pump that was installed around 6 weeks ago.
Remove your belt and spin the pump by hand -- see if you can feel any "grind" in it, or if there is excessive play. Also, give your idler pulleys a spin and see how they feel.
03-17-2009, 09:42 AM #6Junior Member
- Dec 2008
- VA BEACH, VA
Black- 99 Camaro
Question: Water Pump
By psycho_puppies in forum External EngineReplies: 4Last Post: 01-20-2011, 06:23 PM -
Question: water pump
By Pony_Eater in forum External EngineReplies: 8Last Post: 08-31-2009, 04:26 AM -
Water pump going out
By BMJ99Z28 in forum General HelpReplies: 9Last Post: 02-18-2009, 05:14 PM -
Do electric water pumps pump enough water for daily use?
By xinthenight in forum External EngineReplies: 6Last Post: 08-02-2007, 10:04 PM -
Water Pump?
By 5LtrBtr in forum General HelpReplies: 6Last Post: 05-18-2006, 09:44 AM
