Results 1 to 10 of 10
    Decatur Al
    99 Z28
    Water pump going out
    Where is the weep hole on a 99 ls1 water pump behind the pulley? Looks like its ending up on the front of my oil pan and when i turn on my car the low coolant light comes on then if I turn it off then back on no light WTF. I'm sure its not oil I do also have an oil leak but I didn't put green oil in it. It looks wet under the pulley but I can't see the weep hole.
    Feb 2006
    2002 WS6
    The weep hole can be hidden under the pulley. As for the low coolant light, those are less the accurate on a good day, But it does sound like your water pump is leaking.
    yep, weep hole is back there. Pump is probably starting to fail. Pretty easy job to do.
    Bragg NC
    Met. Sunset Orange
    01 SS
    If water is coming out of your weep hole then the seals inside the pump have failed, its time to replace, like orion said its a simple straight forward job..
    J
    Decatur Al
    99 Z28
    thanks thats what I was thinking any suggestions on a good mechanical pump?
    Sep 2008
    kansas city mo
    2000 camaro ss
    i bought the bosch from pep boys ($130) and seem to work just fine.
    Crystal Lake IL
    2001 Camaro Z28 M6
    easy fix, 6 bolts....
    edlebrock, claims their new waterpump flows more.
    Member qwk93ta's Avatar
    Fairfield, Ohio
    00 WS6
    Why not go with an electric WP?
    Nov 2008
    Arkansas City, KS
    2002 Pontiac Trans Am
    It'll only take like ten minutes to change that thing out. You'll spend more time running the air out of the system than you will replacing the pump. Mine did the same thing when it went out. WAY easier than the LT1 in my old Formula.
    Decatur Al
    99 Z28
    Quote Originally Posted by qwk93ta View Post
    Daily driver and I don't have 600 bucks to spend on one.
  1. Question: Water Pump
    By psycho_puppies in forum External Engine
    Last Post: 01-20-2011, 05:23 PM
  2. Question: water pump
    By Pony_Eater in forum External Engine
    Last Post: 08-31-2009, 03:26 AM
  3. water pump
    By Pete Rock98 in forum General Help
    Last Post: 05-17-2009, 01:46 PM
  4. Do electric water pumps pump enough water for daily use?
    By xinthenight in forum External Engine
    Last Post: 08-02-2007, 09:04 PM
  5. Water Pump?
    By 5LtrBtr in forum General Help
    Last Post: 05-18-2006, 08:44 AM
