Thread: water pump
    Pony_eater Pony_Eater's Avatar
    Aug 2008
    Murrieta, Ca
    2000 trans am ws6
    water pump
    I think my pulley is sqeaking on the water pump how hard is this to replace/ is there anything that I can do so I can still drive it for a little while and stop the sqeaking until I have enough to replace the water pump?
    May want to do some diagnostic work first before just replacing parts. Things to check: condition of your belt, belt tensioner, idler pulley, and other driven accessories. One simple check is to shoot the belt with a little belt dressing while the engine is running and see if the squeak subsides. This would indicate that there is belt slippage, either due to wear or a tensioner going bad.
    Aug 2008
    Murrieta, Ca
    2000 trans am ws6
    I have changed the idler pulley, the alternator. the power steering pump/pulley, and the belt within 3 weeks. lol the only thing it can be is the water pump. Im just wondering if theres any way to stop the sqeaking for a while until I have the money to replace it because IM BROKE FROM REPLACING ALL THE OTHER PARTS!!! LOL
    I have had problems with brand new belts in the past -- again, I recommend a quick shot of belt dressing to see if it affects the noise. If the noise goes away, then it is definitely a belt or tensioner issue. If the noise remains, then you need to look at each component individually to locate the source.
    An old timer trick is to place a long piece of wood against each component and hold your ear to the end of it. The noise is transmitted down the wood to your ear. You are simply trying to identify the source by determining where the noise is the loudest. Obviously, getting the wood tangled up in your belts may result in a trip to the E.R. and damage to your car, so you need to be damn careful.
    Aug 2008
    Murrieta, Ca
    2000 trans am ws6
    ok so i replacedthe tensioner today and nothing changed so i believe it has to be the water pump
    Local Tire Smoker blackout5.3's Avatar
    middle of nowhere oklahoma
    01 Silverado
    agreed with pajeff02 belt dressing give it a quick shot its easy and wont hurt anything and may save a few bucks, as for the water pump if it is that when everything else is exhausted isnt to bad after getting the other accessories out of the way, hardest part is getting the gaskets to stay in place when you try and stab it up there, i recomend a little bit of rv silicone on the backside of the gasket on the side of the pump
    Chalfont, PA
    rallye red
    Buy a spray can of belt dressing!!! it is only $3 or $4!!! You could have saved a lot of money by investigating first. The second thing I would buy is an automotive stethoscope, they are only $9 from Jegs or available at your local auto parts store. Then you can listen to where the squeak is coming from before you replace a bunch of stuff needlessly. I just picked up a water pump today at NAPA, It is $204, ,so make sure you need it, mine is leaking.
    Junior Member Bama99z's Avatar
    Jun 2009
    Muscle Shoals AL
    Artic White
    1999 Camaro Z28
    Pony Eater, Replacing the water pump is not hard at all to replace. I just changed ming along with all of the idler and tension pulleys last night after completing LT & ORY install. No problem what so ever. Pricey though around $ 150.00 @ O'Reileys Auto Parts.
    Good luck!!!
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    There are two belt tensioners.
  1. Question: Water Pump
    By psycho_puppies in forum External Engine
    Last Post: 01-20-2011, 05:23 PM
  2. water pump
    By Pete Rock98 in forum General Help
    Last Post: 05-17-2009, 01:46 PM
  3. Water pump going out
    By BMJ99Z28 in forum General Help
    Last Post: 02-18-2009, 04:14 PM
  4. Do electric water pumps pump enough water for daily use?
    By xinthenight in forum External Engine
    Last Post: 08-02-2007, 09:04 PM
  5. Water Pump?
    By 5LtrBtr in forum General Help
    Last Post: 05-18-2006, 08:44 AM
