Thread: knock sensor
03-15-2009, 06:04 PM #1
- Mar 2009
- mwc OK
black- 1998 TRANS AM
knock sensor
hello, I was wondering if anyone knows about knock sensors. my 1998 TA check engine light came on and I took it to autozone and they checked it with the hand held computer, and said it read knock sensor code. is this serious? my car runs fine no knocks or overheating or anything.
03-15-2009, 06:30 PM #2
It needs to be replaced, and is relatively common on LS motors (more for trucks/suv's)
Just remove the intake and the plate under it and you can replace them, get both b/c while your there you might as well replace them both.
If it goes a while without being replaced it can snowball to other things, and also the light will always be on and you wont know if something else goes wrong, and then you end up having to replace more and more things at one time costing more money.
03-15-2009, 07:12 PM #3
- Jun 2008
- ohio
black- 1998 Camaro SS
my tuner told me that i should replace mine in my 98 ss even tho there is nothing wrong with them. He said that especially in 98's they are really sensitive for some reason
03-16-2009, 06:58 AM #4
04-16-2009, 01:35 PM #5
- Apr 2009
- IL
04-16-2009, 01:40 PM #6
i believe there are 2 knock sensors
04-16-2009, 02:47 PM #7
- Jul 2005
- Jacksonville, FL
Yes, there are two knock sensors - both under the intake. Even if you only get a code for one needing replacement I'd replace both, along with the harness.
04-17-2009, 04:45 PM #8
- Sep 2008
- Saint Cloud,FL
1994 Z28 MQBM- 2001 SS #1629 LPM
Yes because you dont want to take the intake off more than you need to. be careful of the vac tube for the power booster, it will snap the oil pressure switch.
knock sensor code with new knock sensors?
By zaaronz in forum General HelpReplies: 13Last Post: 02-27-2011, 06:26 AM -
Knock Sensor ?
By Jheath5193 in forum General HelpReplies: 1Last Post: 01-20-2011, 02:31 PM -
Which knock sensor do I need?
By SMWS6TA in forum General HelpReplies: 7Last Post: 12-27-2010, 10:09 PM -
will bad knock sensor knock down hp
By zaaronz in forum General HelpReplies: 11Last Post: 10-14-2010, 04:49 PM -
Knock Sensor/Oil Pressure Sensor Issue
By Slow '99 in forum External EngineReplies: 1Last Post: 04-04-2007, 08:28 AM
