Thread: Different knock sensor wiring
02-08-2009, 07:50 PM #1
I am in the process of slowly changing my ls1 intake for a fast 92/92 after removing the intake i find my wiring for my knock sensors are different then anything i have seen.
is that normal?
Another quick question in that on the back of the stock intake there is 2 lines, one to the brake booster and the other small line that runs to a sensor. My fast 92 does not have the nipple in the back for the 2nd small line. Where does it go?
02-09-2009, 12:46 AM #2
It's not obvious to me what you think is odd about the wiring?
The small line I believe goes to the heater controls if I remember correctly.
02-09-2009, 01:54 AM #3
yup the small one goes to the heater controls, you can add a vaccum (T) in the large booster line to run the heater controls.
knock sensor wiring is normal
03-02-2009, 10:30 PM #4
One more quick clarification
For the lines on the left i have the top one leading to the back of the intake manifold and the bottom i have capped off. Then i need to cap off the 1 end of the T at the back of the manifold?
03-03-2009, 03:26 AM #5
the short one on the back pointing to the passenger side hooks to a hose coming out of the fire wall that works the heater controls.
plug the other one.
knock sensor code with new knock sensors?
By zaaronz in forum General HelpReplies: 13Last Post: 02-27-2011, 06:26 AM -
will bad knock sensor knock down hp
By zaaronz in forum General HelpReplies: 11Last Post: 10-14-2010, 04:49 PM -
Question: LT1 and LT4 Knock sensor
By JaycenK in forum LT1Replies: 14Last Post: 02-08-2010, 11:33 AM -
Knock Sensor Wiring Gone Bad??? Please Read
By TurdsOfMayhem in forum Firebird / WS6Replies: 6Last Post: 08-20-2007, 07:45 AM -
Knock Sensor/Oil Pressure Sensor Issue
By Slow '99 in forum External EngineReplies: 1Last Post: 04-04-2007, 08:28 AM
