Thread: whats wrong
    I need some money huggerls1's Avatar
    Feb 2007
    chandler az
    hugger orange
    1999 camaro ss
    whats wrong
    ok so i put my kooks lts on with ory and a ported throttle body on. so the exhaust is rattling and i put some rubber hosing underneath to stop it until my bumpstop comes in. my problem is the car seems to loose power if i floor it. i also took out the egr and air systems. waiting to get my bumpstop installed before getting it tuned. ive heard the exhaust rattling causes the knock sensors to go off. would that still be true with the hosing in there? please help.
    Bragg NC
    Met. Sunset Orange
    01 SS
    What codes are you throwing besides the Air codes? Could be the throttle body causing your issues. the banging could set off the knock sensors. The bump stop should cure it, although personaly it didnt for me. I had to cut a piece of pipe out and weld in a new section angled down a bit.
    J
    you can stop that Y from hitting the floorboard by adjusting the over the axle pipe. That angle coming over the axle is how I cured mine.
    As far as it losing power that's tough to tell without a log and without being there to see it. It could be a ton of things.
    Feb 2007
    chandler az
    hugger orange
    1999 camaro ss
    idk what codes exactly im throwing because i dont have a scanner. and i cant adjust the back piping because its all welded by the previous owner. but thanks for the replies.
    Bragg NC
    Met. Sunset Orange
    01 SS
    Chinazone and Advance does free scanning, if you pull the codes and post them up we can help ya further..
    J
    Senior Member karpetcm's Avatar
    Tujunga, CA
    01 Camaro 6speed
    its more then likely knock and your getting timing pulled. Get the codes, also get a tune if you havent yet for LT's.
  1. Can someone tell me whats wrong with this LS2
    By LS2SS in forum General Help
    Last Post: 10-16-2013, 06:41 PM
  2. whats wrong with my headrests?
    By keith455 in forum General Help
    Last Post: 10-02-2013, 07:50 AM
  3. Umm... I don't know whats wrong??
    By WS6Dream in forum General Help
    Last Post: 03-30-2011, 04:33 PM
  4. Help: Whats wrong?
    By TruThug in forum Firebird / WS6
    Last Post: 01-27-2011, 06:01 PM
  5. Question: Whats wrong with my T/A?
    By Dann in forum Firebird / WS6
    Last Post: 06-03-2009, 07:45 AM
