Results 1 to 15 of 15
Thread: maf sensor
    footbrake racer racer426's Avatar
    Jan 2008
    antioch,tn
    2004 gto
    maf sensor
    can anyone tell me if an aftermarket maf sensor is worth getting.mine is a screenless pollished stocker.just wondering the dif. thanks
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by racer426 View Post
    just keep your stock MAF, its good for over 500hp. if you get an after market MAF it will NEED to be tuned and wont give you any gains.....lots of people run into problems with aftermarket MAFs.....its just not worth it
    Jan 2008
    antioch,tn
    2004 gto
    thanks mark kinda figured that just not sure.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    An aftermarket maf is a good thing when you have a great tuner, a lot of cash, a lot of mods and a lot of time to get it right.
    Unless you have all those stick with the stocker. Minimal gains for a lot of cash.
    Jan 2008
    antioch,tn
    2004 gto
    i need a good tuner.don't know of any local here in nashville.i have the coretex programmer from s-chips and it made no hp change on the dyno .just hella shift points.
    Beaver Dam KY
    79 T/A -91 Firebird
    Come to the Horsepower House In Bowling Green?
    mercersburg pa
    hugger orange
    2004
    hey no problem Racer
    one of these days i hope to be a great tuner.
    if you just have bolt ons, you could get a mail order tune from Frost at LSXtune.com
    Retired Outlaw Sum Bitch
    Next step for you will be a speed density tune not an aftermarket MAF.
    mercersburg pa
    hugger orange
    2004
    not much of an altitude change around here.....i love my SD tune
    You betcha
    Member The Silver Goat's Avatar
    Dearborn Michigan
    Qucik Silver Metalic
    2004 GTO - M6
    I've popped the screen out of the OEM MAF.
    The PCM is programmed for the OEM MAF.
    A different MAF will require HP Tuners or LS1 Edit, in other words a brand of software which enables you to smooth out each of 26 cells controlling the engine under various loads.
    Believe it or not popping the screen does a improves the air...
    But, only pop the screen out if you have CAI tubing is smooth and not corigated. The idle sensor on the MAF looks for smooth air and your goat won't hold an idle...
    I tried an off brand MAF in another vehicle, drove it for 30 minutes in the city, on the e-way and the PCM could not adjust. I stalled out 6 times and every light I pulled up to everybody else thought I wanted to race...
    Also, could somebody explain a SD Tune - don't quite under stand the concept.
    SD allows you to map the A/F...timing etc. versus a computer....you can get as aggressive as you wish and are not a slave to the MAF signals....
    Dearborn Michigan
    2004 GTO - M6
    More or Less a MAF Delete???
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by The Silver Goat View Post
    yup...just a tuned MAF delete
    Senior Member qwkgto's Avatar
    OHIO"S only 9 second GTO
    Phantom Black Metalic
    2005 GTO
    +1 speed density way better then a MAF,changed mine out never looked back,the Aussies dont use em why should we..
  1. Help: 02 sensor bank 1 sensor 1-Is this drivers side or Passenger
    By cballweg in forum General Help
    Last Post: 01-15-2012, 11:44 AM
  2. Question: Reading trans temp stock sensor vs aftermarket sensor in pan
    By senicalj4579 in forum Computer & Tuning
    Last Post: 03-29-2011, 08:41 AM
  3. Knock Sensor/Oil Pressure Sensor Issue
    By Slow '99 in forum External Engine
    Last Post: 04-04-2007, 09:28 AM
