    Ann arbor, michigan
    help finding a fuel cut off switch
    im looking to install a fuel and ignition cutoff switch for added security. what i was wondering is it possible to just hook that all up to a regular toggle switch or would i have to buy something else. if i had to buy something else could you supply me with a link? i already have searched jegs and summit (i thought i saw something like that in their magizine). thanks for the help.
    chris
    Laurel, Maryland
    2000 Grand Prix GTP
    2000 Trans Am WS6 M6
    I rigged up a cutoff to my fuel pump so he car can't start unless it is flipped. I used a regular On/Off Switch running between the Fuel Pump Relay (under the hood) and the Fuel Pump.
    you could also wire it into the vats system. Look at the sticky in this section on bypassing the vats. It would basically be the same thing except you'd have to wire a switch in to enable vats. Which brings up the question if you have vats that will already interupt fuel and ignition why would you want to wire in another fuel/ignition disabler?
    Ann arbor, michigan
    what is vats? sorry for my iggnorance.
    chris
    Ann arbor, michigan
    ok so i found out what vats is. my car does have the stock secuirity system in it right now. would that have a fuel cut-off. second im going to get a viper alarm system do those have it?
    chris
    Laurel, Maryland
    2000 Grand Prix GTP
    Quote Originally Posted by 00camaro16 View Post
    chris
    Vehicle Anti-Theft System
    I think...
  1. Help: Would it be bad to put my fuel pump on a on/off switch?
    By jrbonds in forum General Help
    Last Post: 04-06-2015, 03:34 PM
  2. E85 Fuel Switch - How It Works
    Last Post: 08-18-2011, 04:40 PM
  3. help finding a fuel cutoff switch
    By 00camaro16 in forum Stereo and Electronics
    Last Post: 11-22-2008, 07:51 PM
  4. FJO and/or Fuel Pressure Safety Switch
    By captainwizbang in forum Nitrous
    Last Post: 09-04-2007, 11:21 PM
  5. fuel pump cut off switch location??
    By truakita in forum General Help
    Last Post: 07-24-2007, 02:50 PM
