Results 1 to 10 of 10
Thread: Stupid Question
    retired racer not 4 long chevy1966's Avatar
    mississippi
    red white
    1999 z28 vert 1998 z28 ht
    Stupid Question
    If I install the Eibach 1.2" lowering springs on my car, do I have to change the shocks, ie Konis or revalved, or can I just use my factory Bilsteins? I know I will have to install adjustible panhard bar to center the rear. Thanks in advance for all support.
    O.C. California
    2002 Camaro SS (crashed)
    (No stupid questions, just stupid people J/K this is what Forums are for, a place for help)
    Changing the stock shocks is not required to lower a car. 1 1/2 isn’t that much anyway. A wheel alignment would be a good idea though. The pan hard bar is not required either because you’re changing the pinion angle not the alignment. A torque arm bar would fix that if it became a problem.
    And for those who much chime in with perfect geometry... New shocks would help because your compression the stock shocks when lowering and that takes a little of the travel away. Stiffer shock would help prevent bottoming out and improve performance.
    mississippi
    red white
    another stupid question
    My car is a convertible and Eibach shows the springs do not fit a convertible. What are my options?
    O.C. California
    really? hmm I didnt know there was a difference. Probably because Verts need more frame support and weight more. You could just call them to be on the safe side or look into a different manufacture
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    Quote Originally Posted by chevy1966 View Post
    You are referring to Sportlines.
    They actually fit with no problem... but I recommend you put the Prokits instead of the Sportlines.
    several reasons for that...
    1. more suspension travel
    2. linear spring rate
    3. higher spring rate.
    combining all 3 not in favor of Sportlines together, it's a situation where it's almost impossible to dampen the spring rate properly.
    You'd end up haveing 2 choices... overdamping the system, killing the shocks and not letting the springs do their work, or bottoming out constantly if you go w/ Sportlines.
    Been there, done that, cost me 2 rear koni DAs... then upgraded to Prokits.
    Eugenio_SS
    O.C. California
    That’s what I was thinking too. I have a coupe with Sport lines and Koni DA and don’t have a problem. But the added weight of the vert is just enough the throw it off. Better stick with the Prokit. I had Prokit of a previous camaro and it worked great but I wanted a lower spring this time so I went with the Sport line.
    Allen, TX
    2001 Trans Am
    whats the difference between the pro kit and the sportlines?
    O.C. California
    Sportline kit is lower
    mississippi
    red white
    Thanks for the help. I ordered my Eibach kit yesterday, hopefully it will be here by this weekend.
    O.C. California
    No sweat man, drive safe.
  1. stupid question
    By cags07 in forum Camaro / SS
    Last Post: 07-22-2010, 07:32 PM
  2. stupid question
    By Lunatikgixxer in forum Firebird / WS6
    Last Post: 07-17-2010, 07:33 PM
  3. Stupid Question
    By bsteff in forum Stereo and Electronics
    Last Post: 07-12-2010, 06:33 PM
  4. Question: stupid light stupid question
    By TAallday in forum LT1
    Last Post: 08-26-2009, 10:58 PM
  5. stupid question
    By FSANE in forum Political / Debate Forum
    Last Post: 10-25-2008, 06:12 PM
