    Florida
    2001 Corvette
    Oil Pressure sensor
    Hello All. I'm new to the site and to online chats so be patient please. I do need some help. I have an 01 Vette and need some help locating the oil pressure sensor. I thought it would be at the filter but it does not match the new one. The new unit has 3 wires. I'm not sure this is right.
    Senior Member
    Jacksonville, FL
    Not sure on yours, but on the F-body is on the drivers side, right behind the intake manifold and screws in vertically.
    My Neighbors Hate Me!!! lvbroham1's Avatar
    Jun 2006
    Ft. Lee, Virginia
    Artic White
    2001 Chevy Camaro SS
    Quote Originally Posted by 2001NBMZ28 View Post
    Easiest way to get to it and get it changed is to remove the intake manifold.
    Junior Member 1 TRANS AM's Avatar
    BRENTWOOD TN
    BLUE
    02 TRANS AM
    Quote Originally Posted by lvbroham1 View Post
    X 2
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    Drivers side in back of the intake manifold. Yes manifold has to come out to get to it. Pus you need the special oil pressure sensor socket. It's the tallest sensor back there. Be sure when you install the new sensor, you route the vacuum hosing properly or you'll break the sensor
    Member mikeaford's Avatar
    Fredericksburg Va
    01 Trans Am
    Plus one on being careful with the hose seen em "snap" and you don't want that if you have to remove the intake a second time route it the correct way and save yourself in the future!!! Also might want to look into replacing Knock sensors while you are in there and don't forget to use new intake gaskets!!! Little now will save you in the end. Take care.
    Florida
    2001 Corvette
    Thank you to all that responded. I have been building cars for 30+years but it always helps to learn from others experence. thanks again.
    NC
    1998Z28
    Talking
    Quote Originally Posted by Redphoenix1998 View Post
    YOU DO NOT have to remove the intake manifold to change out the oil pressure sending unit. Just crawl your ass on top on the engine and it can be done in less than 15 mins time. YOU DO NEED the correct sender socket. I bought my thin walled socket at NAPA. A regular thickness socket is to thick to get it all the way on.
  1. Oil Pressure Sensor
    By CWW17 in forum General Help
    Last Post: 04-20-2007, 07:06 AM
  2. Knock Sensor/Oil Pressure Sensor Issue
    By Slow '99 in forum External Engine
    Last Post: 04-04-2007, 08:28 AM
  3. Oil pressure sensor
    By blomeup647 in forum General Help
    Last Post: 04-03-2007, 03:42 PM
  4. Oil Pressure Sensor Connection
    By blomeup647 in forum Internal Engine
    Last Post: 04-02-2007, 07:06 PM
  5. Oil pressure sensor hints?
    By imflyn in forum General Help
    Last Post: 03-15-2007, 10:48 AM
