LS1 Performance Information Kentucky-Speed TunedbyFrost Mahle
Go Back   LS1 Performance Information > LSx Technical Help Section > General Help
Online Store Sponsors Rules
Notices
New Era Performance Zaino Autotrix
Reply
Thread Tools
Old 04-02-2007, 08:04 PM   #1
blomeup647
95 Camaro
Teal
Oil pressure sensor
Question???? I tried to change the oil pressure sensor on 2000 LS1. I went to the dealer the sensor they sold me has 2 pins, my old sensor only has 1 pin. I went back to the dealer and they told me there is harness adapter, the new harness adapter has 2 wires, my harness in the car only has 1 wire.
DOES ANYBODY KNOW WHAT TO DO?
blomeup647 is offline   Reply With Quote
Old 04-02-2007, 08:22 PM   #2
blomeup647
95 Camaro
Teal
I got 95 Z28 with an LS1 in it.
Old 04-03-2007, 02:04 PM   #3
2001NBMZ28
Senior Member
Don't know what's going on - I do know there's a difference in the 98 and the99-02 OP sensor part numbers, but don't know about the pins. 98 is 12559781 and other is 12562267. I'd think a "harness adapter" would have 2 pins for the sensor end, and one pin for the car harness???? TTT for you, maybe someone knows for sure...
2001NBMZ28 is offline   Reply With Quote
Old 04-03-2007, 02:14 PM   #4
2001NBMZ28
Senior Member
Does your old sensor look like this? http://shbox.com/1/op_sensor.jpg
Old 04-03-2007, 04:27 PM   #5
blomeup647
95 Camaro
Teal
Yeah, actually my oil pressure sensor looks like that one with one wire, but the sensor is in a different part of the block behind the intake. Part number 12559781 is for the sensor that I got from the dealer which has 2 pins. Part number12562267 is for sensor with 4 pins for the newer ls1.
Old 04-03-2007, 04:42 PM   #6
2001NBMZ28
Senior Member
Is it possible your car was using an LT1 sensor, in the LS1 port since it's a '95?
Reply
T-Tops Online Fast Toys Performance Third Shift Studios
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GM Parts Direct
One of the largest message boards on the web !
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
