Results 1 to 2 of 2
Thread: New Halos Melting Lense? Help!
10-20-2008, 03:54 AM #1Member
- Apr 2006
- Jeffersonville, Indiana
Monterey Maroon Metalic- 2000 Z28
http://cgi.ebay.com/ebaymotors/_Car-...=p4506.c0.m245
Alright guys, this weekend I installed my new Halo lights at my in-laws' place. During the 2 hr. drive home it got past dusk and the low beams came on automatically as usual and burned for about 30 min. before I parked my car in the garage. Since it was genuinely dark for the first time since I did the install, I got out and checked out the lights and noticed the lenses had little blisters right where the low beam light was shining. These spots were extremely hot!
They are the same model as shown in the link above except that the lens is smoked (I could not find the exact model for sale).
I wired the lights in the following manner:
Factory Lighting Coinciding with Halo Light Assembly
Daytime Running Corners -----> Orange Bulbs Only
Fog Lights + Corners -----> Orange Bulbs + 3 Corner LEDs + Halo Rings
Low Beams + Fogs + Corners -----> Orange Bulbs + 3 Corner LEDs + Halo Rings + Low Beams
Anyone familiar with these lights know that the accessory lights have to be spliced into corner/turn signal lighting or fog light wires to work but that the low and high beam bulbs simply attach via stock harness.
Info that may be helpful:
These low and high beam bulbs are HID (High Intensity Discharge), I assumed that no special hardware or wiring was needed and plugged them directly into the stock harnesses.
During the course of the install and ensuring that the splices were done correctly, etc. my battery ran low and I had to take a jump from my father in law.
I noticed that when I use my turn signal now, it clicks nearly 2X faster than it did prior to the Halo install.
Any ideas?
10-23-2008, 08:50 PM #2
The problem with the turn signals blinking faster is due to not enough resist being created by the LEDs installed in the turning signals. Adding some resistors to each spot where the LEDs are will resolve this issue.
This link might help it explain it better for you:
http://led.linear1.org/why-do-i-need-a-resistor-with-an-led/
clear halos or black halos?
By bowtieguy02SS in forum Camaro / SSReplies: 54Last Post: 01-19-2009, 11:23 AM -
Put in a new lense/bezel... NOW
By JoshieDoom in forum Appearance SectionReplies: 7Last Post: 07-26-2008, 06:10 PM -
Tire melting 101
By JJWON in forum Almost Anything GoesReplies: 16Last Post: 03-29-2008, 09:12 AM -
tailight is melting!!!!
By bluefields88 in forum Stereo and ElectronicsReplies: 30Last Post: 02-24-2007, 01:42 AM -
Need Third Gen turnsignal lense
By SmokinSS in forum Parts Wanted / TradeReplies: 0Last Post: 01-08-2007, 10:59 AM
