Results 1 to 2 of 2
Thread: Clutch Swap
    Member Bouvers's Avatar
    Blue 1997 Trans Am(Sold)
    Pewter 2001 Trans Am Vert
    Clutch Swap
    Quick question I want to know if its necessary or worth getting ARP flywheel bolts for the install... is it a torque to yield and therefore require new bolts everytime?
    Edit: More questions, is it worth changing out the Pilot Bearing while doing this swap the car only has 24k miles. In the write up I see they also suggested replacing the rear main seal... I figured that was unnecessary but let me know.
    thanks in advance.
    bump
  1. LS7 clutch swap
    By firehawkchick in forum General Help
    Last Post: 10-08-2013, 08:30 PM
  2. What else is required for a clutch swap?
    By GottaHaveLS1 in forum Manual Transmission
    Last Post: 06-17-2009, 07:26 PM
  3. Shop for doing clutch swap in SLC?
    By TheDoc in forum Manual Transmission
    Last Post: 11-11-2007, 04:51 PM
  4. Clutch Swap
    By TAMAN77 in forum Manual Transmission
    Last Post: 03-31-2007, 12:02 AM
