Results 1 to 20 of 31
Thread: LS7 clutch swap
    Junior Member firehawkchick's Avatar
    Apr 2012
    Illinois
    2000 Trans Am Firehawk
    LS7 clutch swap
    About two weeks ago my stock LS1 clutch went out with 69k miles on it. I decided to upgrade a little and go with the LS7 kit. Everything is installed and the clutch was bled and theres no air in the lines. The clutch needs to be pushed all the way to the floor and it engages about an inch off the floor. It seems very low to me and very uncomfortable. After doing some research I found that a lot of people said that they engage low and they shim the slave to create a higher engaging point in the clutch. Anyone have any ideas or has anyone done the swap?
    Sent from my SCH-I510 using Tapatalk
    nikki
    Henryetta/Tulsa Oklahoma
    2016 Camaro SS - Summit
    2001 Trans Am WS6 - NBM
    I do believe an adjustable master will solve your problem. Gives you control on where the pedal engages. I didn't do that and had no issues with my swap, so not sure what exactly the problem is. Could be your master is no bueno and also needs to be replaced anyway.
    Sent from my Samsung "Look it's The Darkness!!!" Infuse 4G
    Apr 2012
    Illinois
    How far off the floor does yours engage? Did you use the ls1 slave and throw out bearing or a different one?
    Quote Originally Posted by firehawkchick View Post
    About 1/4 pedal it would start to engage. LS7 clutches are self adjusting as well. It will relax a bit over time. There is a break in period of about 500 miles or so. I used LS1 everything except the clutch kit (clutch and flywheel). As I recall now, the clutch did engage pretty much right off the floor for the first week or so.
    Apr 2012
    Illinois
    Im gonna drive it for a week or so and then decide if I should shim it.
    What Would Earl Do? Vexzer's Avatar
    Kirby, TX
    Fire
    2002 SS
    I put a LS7 clutch in mine at about 60,000 miles. Put in a new GM slave throw-out at the same time. The slave was expensive but I've had no issues & clutch holds very well. If I was to do it again I would find a lighter flywheel though -lots of free HP there.
    Apr 2012
    Illinois
    Where did it engage at?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    I don't have a LS7 set-up, but when I first installed my Spec Stage 3+ clutch, it engaged damn near the floor. After about a 500 mile break-in, the clutch pedal started to engage a little further up. I'm still using my stock slave and MC. Been fine for the last 14K miles now.
    This....mine did the same thing.
    Apr 2012
    Illinois
    I guess im gonna drive it and see what happens its just really uncomfortable because im really short.
    I'm 5'8" so I have to move the seat up close too. How tall are you?
    Apr 2012
    Illinois
    Barely 5 foot!
    wow, you need a booster seat to drive......
    It will move up. However, an adjustable MC like mentioned might be a good investment for you. That way you can set it to engage where you want.
    Apr 2012
    Illinois
    Close but no booster seat for me! I might shim it.
    James Bond Spikito's Avatar
    2001 3.8 Black - sold
    2000 SS Black M6
    I put in a LS7 clutch and an adjustable Tick. My engagement was right off the floor, but after a few miles, 500 or so, it moved up quite a bit, and now its about halfway off the floor
    Apr 2012
    Illinois
    What exactly is a tick?
    Quote Originally Posted by firehawkchick:2763096
    Tick is the manufacturing company that makes an adjustable master cylinder which gives both a 15% increased flow rate of the hydraulic fluid and the ability to adjust where your clutch peddle engages.
    Apr 2012
    Illinois
    Thanks!
    Apr 2012
    Illinois
    Pulled the trans again today to do the slave shim but everythig measures accurately so it doesnt need a shim. Guess ill be buying the mc.
  1. What else is required for a clutch swap?
    By GottaHaveLS1 in forum Manual Transmission
    Last Post: 06-17-2009, 07:26 PM
  2. Clutch Swap
    By Bouvers in forum Drivetrain
    Last Post: 10-19-2008, 08:25 PM
  3. Shop for doing clutch swap in SLC?
    By TheDoc in forum Manual Transmission
    Last Post: 11-11-2007, 04:51 PM
  4. Clutch Swap
    By TAMAN77 in forum Manual Transmission
    Last Post: 03-31-2007, 12:02 AM
