Results 1 to 19 of 19
    Member gonzo99ta's Avatar
    Louisiana
    99 Trans am
    Question how to remove paint overspray?!
    Alright i really screwed up!
    I was touching up the paint on my camper jacks and must have been too close to my truck especially with the wind. Truck was dirty when i was doing all this, so never noticed it until i went to wash it. Now i have white paint over spray on my truck. What can i use to remove this safely? Is it going to require a wet sanding to remove or is there a chemical solution that will not damage the crear coat?
    Member Piranhaz's Avatar
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Quote Originally Posted by gonzo99ta View Post
    I'm sure everyone has their own method but if it was me, I would hit it with a little 2000 grit wet and buff. It will be the least amount of work and won't damage a thing.
    Member slikws6's Avatar
    Feb 2008
    southeast
    1998 WS6 Convert
    Try a clay bar.
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    I'd definetly try to claybar it out first. Sanding and buffing will take a lot more time and effort to do it right than the bar.
    I had a little on mine when they fixed a dent on my rear quarter panel. Used a claybar and it came right off.
    Member chuck4345's Avatar
    memphis tn
    2002 trans am ws6
    we have this happen all the time at work we use a buffer to get it off
    Louisiana
    99 Trans am
    i guess i'll try the clay bar 1st and see if that works.
    Thanks for the help.
    STL
    RED
    2001 CAMARO Z
    i am a painter and got overspay on my truck, i was able to just wax it right off. there is alot of other way also
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Have you waxed the truck in the recent past??
    As long as it has had a coat of wax on it, you should have no problem either using a claybar or wax to remove the overspray.
    Overspray really only seems to be a problem on a freshly painted vehicle that has never had a coat of wax on it and the paint is still curing.
    Junior Member tiny47's Avatar
    Finleyville, Pennsylvania
    Midnight Blue
    2001 WS6 TRANS AM
    I used a clay bar... Worked great.
    Jan 2008
    CORUNNA
    2002 WS6
    overspray removal
    paint thinner will work
    Senior Member GULLETT17's Avatar
    Muncie, IN
    00 TA PWTR, 98 VertTA NBM
    80 TA BLK, 80 Formula NBM
    id just use zymol . . .
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Quote Originally Posted by rstewart View Post
    I would not recommend this unless you are very careful....................
    Austin, TX
    99 Trans Am(sold)
    I would never let paint thinner touch my car.
    Think about it. Why would you let something that is designed to remove paint, on a painted surface that you don't want to be removed.
    If you wax your car regularly, like most of us do, clay bar is the best thing to attempt first. If that doesn't get it out you may have to wet sand then buff. Both of these, done properly, are a lot less likely to damage the clear coat or, god forbid, go through to the paint on your vehicle.
    Muncie, IN
    Quote Originally Posted by Mike's TA View Post
    Paint thinner is designed to thin paint for application not remove it.
    However, it would be very risky to use it for this cleaning application. If you want to try a liquid cleaner, I'd try plain old rubbing alcohol. But even after using this, you may have to polish afterwards.
    Aug 2008
    Minnesota
    1999 Trans Am M6
    Quote Originally Posted by GULLETT17 View Post
    Navy Blue Metallic SS 01NBMSS's Avatar
    Hendersonville NC
    Navy Blue Metalic
    Gasoline will work most likely with a little elbow grease paint thinner will work also either way get the paint off and then wash off the gas and wax again because gas will eat through the wax on the car
    Member jujofields's Avatar
    Lafayette, Indiana
    Pewter Metallic
    2002 Trans Am WS.6
    Definitely try using a clay bar first...in most cases, they work really well to remove paint overspray. Also keep in mind that some clay bars come in different "grits" so it might be worthwhile to get a little bit more abrasive clay bar if the type you initially use doesn't get the overspray off....
    Member squee's Avatar
    Baton Rouge
    2000 SS M6
    It won't harm the paint. Urethane based paint won't be affected.
    Jan 2008
    CORUNNA
    2002 WS6
    laquer thinner i was told one could use but be sure to rewax that area again
  1. How do you remove house paint from a car?
    By FishinCricket in forum Showcar and Detailing
    Last Post: 05-05-2013, 05:27 PM
  2. Question: How To Remove Overspray?
    By fbodyNATION in forum Showcar and Detailing
    Last Post: 10-25-2011, 04:42 AM
  3. Paint dust/overspray removal question
    By HOBS in forum Showcar and Detailing
    Last Post: 07-15-2010, 11:04 AM
  4. want to remove stripes, will my paint look bad?
    By ls1guy23 in forum Appearance Section
    Last Post: 06-01-2008, 05:51 PM
  5. Paint overspray
    By mxkx250 in forum Showcar and Detailing
    Last Post: 07-02-2007, 05:59 AM
