Results 1 to 10 of 10
    Apr 2012
    Lebanon, MO
    1999 Trans Am
    How do you remove house paint from a car?
    At least I think it's house paint... Some dumbass thought it'd be cute to kick a paint can over the wife's sons car.. The lid came off and some paint got on the hood.. How would I go about removing it? Any suggestions would be appreciated.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    Most house paint is latex or water based. I would start with a good compound wax, keep the cloth wet and do not stay too long on one spot. When you are done, finish waxing the car then drive to the dumb ass's house and punch him in the mouth. Done.
    Member Sas's Avatar
    Loveland/Ft. Collins, CO
    Blue
    2001 Formula Firehawk
    Have you tried using a claybar on it?
    Coral Springs, Fl
    Sunset Orange Metalic
    Do you have any pictures? i would think i good compound should remove it if it's not too bad
    DFW
    '18 CTS-V
    '13 ZL1
    I am in agreement with what has been said so far. If it is a latex or water based paint, you will be able to remove it without issue. I had the pleasure of doing that to the lady's Trailblazer after she drove through paint. I used warm soapy (extra soapy) water, and detailer spray once I found the paint was latex based.
    If the paint is enamel, it's oil based and cannot be removed in the above manner. That would be a costly issue to resolve, as solvents/thinners/cleaners are used to clean enamel based paints. Those have the potiental to damage clearcoat and paint. Obviously, not good.
    Hope this helps. Good luck!
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Good to see you around.
    Apr 2012
    Lebanon, MO
    1999 Trans Am
    Thanks for the replies, guys.. This question and a few others has lead me to the detailing forums and started me down that path, I gotz my shizzle in order now.
    Member ZForce1's Avatar
    Maine
    1999 camaro Z28
    At least he didn't put the latex paint on the car on purpose - like a friend of mine did once - took brown latex paint and a roller. He rollered paint over bugs, bird droppings and all. It was a '79 Caprice. A turd anyway.
    Apr 2012
    Lebanon, MO
    1999 Trans Am
    Quote Originally Posted by ZForce1 View Post
    Wow!!!
    Member 98ramairguy's Avatar
    Hamburg, NY
    1998 Trans am WS6
    Clay bar should work well it gets a lot tougher stuff off with enough patience
    1998 Trans am Ws6, T56 : SLP Lid, K&N Air Filter, Smooth Bellows, Granatelli air foil, LS6 Intake, SLP Harmonic Balancer pulley, QTP 1 3/4" headers and Y-pipe, LS7 Clutch & flywheel, Hurst Billet Pro shifter,Tick Master Cylinder, UMI LCA relocation kit, UMI LCA, UMI Panhard Bar, Tuned by Frost
  1. House of Kolor Paint System 1969 Pontiac Firebird
    Last Post: 04-27-2009, 10:50 AM
  2. Help: how to remove paint overspray?!
    By gonzo99ta in forum Showcar and Detailing
    Last Post: 12-01-2008, 03:17 AM
  3. want to remove stripes, will my paint look bad?
    By ls1guy23 in forum Appearance Section
    Last Post: 06-01-2008, 06:51 PM
  4. is there any way to remove spider webs in paint?
    By greatwhiteZ28 in forum Showcar and Detailing
    Last Post: 04-25-2007, 06:10 PM
  5. Replies: 12
    Last Post: 02-25-2006, 08:34 PM
