Thread: Not Starting?
    Member BlueMagicSS's Avatar
    Oakland, California
    Candy Blue
    Not Starting?
    Ok, a buddy's car won't start after a new clutch and starter. It was starting fine for a few days but all of a sudden when you turn the key, the guages shut off, and it does nothing. It ran and drove fine for a few days but now won't do anything. Any suggestions? info on what to check??
    1996 383 LT1 M6
    Feb 2006
    Orange County, NY
    always dirty
    2013 Ram 2014 Caddy ATS
    Check the connections on the starter first. Make sure nothing got pinched or burnt either.
    Member Pete Rock98's Avatar
    Bronx NY
    1998 z28
    Make sure all connections are good ,the battery & black wire going the the starter I know on the ls1 starters you have to be real careful when you tighten up the negitive wire .The connection is a metal stud secured by plastic and they break easy .Also put a multi meter on the terminals and make sure battery is good.
    agree, sounds like a starter wiring issue.
  1. ss starting to age
    By slimss in forum Camaro / SS
    Last Post: 01-31-2013, 12:32 PM
  2. Question: Starting
    By travis20 in forum Internal Engine
    Last Post: 12-27-2011, 11:41 PM
  3. Another non starting lt1
    By swimdunc in forum LT1
    Last Post: 07-27-2010, 06:04 PM
  4. Starting over New
    By BULLET_WS6 in forum Internal Engine
    Last Post: 04-19-2008, 07:44 PM
