Results 1 to 10 of 10
    Denton (Dallas)
    2003 GTI 1.8T :(
    Starting over New
    ok...as many of you may know... my car is gone on monday, and i will have a good amount of cash in hand
    Im buying a cheap z28, and am planning on dumping around 3 grand into it right off the bat... the first 1000-1200, will be qtp lt's and some sort of 3" td's dumped before the axle
    I already have a cam I want to use, but thats all i have for the valvetrain...
    its a 231/237 tsp cam... lift is .592/.598 and 112+2 lsa...
    now the company doing the install has the springs (duals) picked out, and the retainers, all those goodys, i will be keeping stock pushrods, or replacing them with new stock pushrods
    i need help picking out a better set of underdrive pulleys, water pump, or is it oil pump? idk w/e you are supposed to replace with it all... and then i just need a basic ls2 timing chain kit? or is their better?
    Later on in this cars life it will receive a 9", and then a fast 90/90 ported, and a set of trickflows... but until then i need help setting up this cam install....
    Georgia
    2014 Camaro 1LS
    I missed it...........where is your car going Monday ?
    Denton (Dallas)
    2003 GTI 1.8T :(
    sold... to a friend... so i can start over new, and not have any car payments... meaning i will already have abit of cash todrop on it, get a beater car, and then i will be making close to 600 a month that can go straigt into mods.... but during summer i should be doing mods faster...
    Georgia
    2014 Camaro 1LS
    Quote Originally Posted by BULLET_WS6 View Post
    sounds like a good plan
    Denton (Dallas)
    2003 GTI 1.8T :(
    yep... got any idea on the parts i need?
    Georgia
    2014 Camaro 1LS
    sorry I am not that far YET in the mods dept
    Denton (Dallas)
    2003 GTI 1.8T :(
    me neither... ok i found the timing chain kit on sdpc, for 37....
    now... anyone know... is it the oil pump or water pump you replace.... i can't remember for the life of me but my instinct tells me oil pump... like... ls6 ported oil pump? and what kind of pulleys...
    Georgia
    2014 Camaro 1LS
    pm 7CAMARO7 he just put a underdrive pulley on his car
    yep, ported ls6 oil pump. IMO it's a bad decision to keep stock push rods. I would go with a hardened set. I personally run a powerbond under drive pulley and I would just get an ls2 chain for around $40.
    Denton (Dallas)
    2003 GTI 1.8T :(
    alright... can i ask why you say that abotu the push rods? fromwhat i understand is it is a small powerloss and acts as a "fuse" that will just bend rather than snap and could save your engine... but if you make a good argument which would you recomend... ultimate goal... is to build a monster of a h/c car... running slicks on a 9"
  1. ss starting to age
    By slimss in forum Camaro / SS
    Last Post: 01-31-2013, 12:32 PM
  2. Question: Starting
    By travis20 in forum Internal Engine
    Last Post: 12-27-2011, 11:41 PM
  3. Another non starting lt1
    By swimdunc in forum LT1
    Last Post: 07-27-2010, 06:04 PM
  4. Not Starting?
    By BlueMagicSS in forum General Help
    Last Post: 10-17-2008, 04:09 AM
