    Dublin, OH
    2000 Trans Am WS6
    Headlight Will Not Stay Up
    Problem: When I turn on the headlights, the driver-side headlight comes up and goes right back down. I talked to my uncle, and he thinks there is a piece that fell off (that keeps the light up).
    Any ideas? Do you know what this part is called, and can I order it without ordering a new motor?
    Thanks!
    Feb 2006
    2002 WS6
    Does it make any noise? what about when you put them down or arm the car? Could be the gear inside the motor. May be a piece of the armature that operates it.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Most likely the arm that goes to the motor has either broken, come loose, lost the nut, or something like that. Im dealing with mine comming loose all the time.
    38 of 139 PontiacFan's Avatar
    Kearney, NE
    2001 Pontiac
    www dot bfranker.badz28.com/headlightfix/index dot htm
    Replace the gears if it's not a loose arm. (Which I doubt, ..., If it goes up, then goes back down, that tells me it's attached.)
    You can turn the gear 180 degrees & get by. But the plastic gear will just do it again over time.
  1. 3.73 or stay at 3.42
    By screamin chicken in forum Drivetrain
    Last Post: 08-29-2007, 07:22 PM
  2. A3 or stay A4?
    By LT1CST in forum LT1
    Last Post: 05-01-2007, 11:54 AM
  3. Should I stay or should I go????
    By OSU Buckeyes in forum Almost Anything Goes
    Last Post: 01-26-2007, 03:14 PM
