Results 1 to 10 of 10
Thread: A3 or stay A4?
04-28-2007, 09:47 PM #1F-bodies is GOD
- Aug 2006
- Ontario, California
Teal Green w/White Stripe- 94 LT1 385 stroker Camaro
A3 or stay A4?
Well here we are again. This is my third 4l60E tranny that I have owned in my LT1 Camaro. My car is currently a stroker and is assigned to the drag strip only and im not sure if I want to go with the Th350 or 400 or rebuild AGAIN the 4l60e. I would like to hear from both people with both transmission to give insight pros cons etc... Thanks
Chris
04-28-2007, 09:56 PM #2!!!!!!!!!!!!!!!!!!!!!!!!!
- Jan 2007
- Rockford, IL
Silver- 2000 Camaro SS
question: does the "e" in the tranny code refer to electric overdrive? in which case the a4 has one but the a3 does not?
04-28-2007, 10:50 PM #3F-bodies is GOD
- Aug 2006
Yes. 4l60e is the electronic shifting tranmission. 700r4 is the same as the 4L60E but with out the "e". And its an 4speed Auto. I have no use of the OD auto anymore. MY car is strickly a drag car. Thats why im considering going old skool with the TURBOS
Chris
04-29-2007, 01:44 AM #4
If you're blowing 4L60Es, then dont bother with a TH350. It is going to have the same size internals. If it's a drag only car, there's really no debate... a TH400 would be perfect for you.
04-29-2007, 06:59 AM #5
04-29-2007, 07:58 AM #6F-bodies is GOD
- Aug 2006
A local tranny shop did. Turbo 400 is what I was leaning more towards. What trannies are you guys running?
04-30-2007, 05:53 PM #7
04-30-2007, 06:08 PM #8
TH400 = Practically Indestructible.
TH350 is a stout transmission too, they definitely seem to be stronger than 700R4s or 4L60s.
04-30-2007, 06:48 PM #9
05-01-2007, 11:54 AM #10Senior Member
- Feb 2006
- Orange County, NY
a t400 is slightly heavier and will use a little more horsepower than a t350, but is the same length of a 7004r so you dont need a new driveshaft or have to move the crossmember. it also has a higher first gear than the t350. how much horsepower and torque is your engine putting out?
Won't Stay Logged In?
By '99 SLP#24 in forum Request and FeedbackReplies: 2Last Post: 03-08-2010, 07:25 PM -
3.73 or stay at 3.42
By screamin chicken in forum DrivetrainReplies: 5Last Post: 08-29-2007, 07:22 PM -
Should I stay or should I go????
By OSU Buckeyes in forum Almost Anything GoesReplies: 38Last Post: 01-26-2007, 03:14 PM -
Car won't stay running - help!
By 408WS6 in forum General HelpReplies: 6Last Post: 11-14-2006, 07:50 PM
