Thread: exhaust rattle
10-12-2008, 11:40 AM #1
exhaust rattle
Ok I just put pace setters lts and a ory and now it rattles heat shields and it sits on a exhaust bracket or crossmember whatever that is... any suggestions on how to stop the rattles... thanks
10-12-2008, 12:55 PM #2
I have pacesetter long tubes and off road Y-pipe on both of our SS's and I had this problem both times.
As far as the crossmember goes,,,that's as simple as readjusting the pipes and fiddling until you are happy with the fit.
The biggest issue I had with both cars is the other problem you described. Driver side Y-pipe hitting the floor/heat shield area. Everytime I hit the gas it would bang the floor.
I found that when you clearance the crossmember it made it closer to the driver side floor and visa/versa. I only had clearance for one or the other and no amount of adjustment really worked to my satisfaction.
My solution was to cut the driver side Y-pipe both at the header collector and the Y-juction and pull it down about 1 1/2 inches and then re-weld it.
This gave me the added clearance on both cars that I needed for engine movement. Also made it easier for me to access the bung I welded in for the wideband on both cars.
10-12-2008, 02:45 PM #3Junior Member
- Oct 2008
- New York
Pewter- 2000 camaro ss slp
Check the o2 sensor's if there new . Mine rattled to the point where I thoght the flow through cat's blew apart.
10-12-2008, 08:16 PM #4
well the o2 sensors are the stock ones... but it sounds more like its rattling agianst shit because ive destroy cats already and doesnt sound like that
10-15-2008, 09:25 AM #5おれわCamaroがいじん!
- Apr 2007
- Washington D.C.
Black- 1998 Chevrolet Camaro SS
Borla all the way with Dynatech headers...no problems with mine the whole time.
exhaust rattle???
By bluefields88 in forum External EngineReplies: 10Last Post: 01-29-2009, 01:37 PM -
exhaust rattle help please
By Bandit1 in forum External EngineReplies: 3Last Post: 02-20-2008, 02:48 PM -
Can't stand this exhaust rattle
By Midnight02 in forum External EngineReplies: 3Last Post: 04-14-2007, 08:57 AM -
exhaust rattle
By Vette LS-1 in forum CorvetteReplies: 2Last Post: 04-26-2006, 12:09 PM -
Exhaust Rattle!!!
By jeffsredt/a in forum Firebird / WS6Replies: 5Last Post: 03-20-2006, 03:44 AM
