Thread: Can't stand this exhaust rattle
04-13-2007, 02:51 PM #1
Hello all. Here's the scoop....I have Hooker Longtube headers and an off-raod y-pipe that meet up to a Flowmaster cat-back exhaust. I'm getting a ton of metallic sounding exhaust rattle in the 2,300 rpm range. I've noticed that the rattle isn't as bad after installing the SFC's, however something is causing the system to rattle. I know the exhaust runs VERY close to the driveshaft and maybe that has something to do with it.
Has anyone had a similar problem with their exhaust and if so, what did you do to fix it? I've thought about picking up the heat wrap that you use on non-coated headers and thought it might be heavy enough (and soft enough) to help stop the vibration/rattle. What do you guys think?
And yes, I know that Flowmaster doesn't flow anywhere near the other high-end mufflers on the market, but I LOVE the sound.....hence, replacing the exhaust system to get rid of the rattle would only be a last resort solution.
04-13-2007, 07:34 PM #2Junior Member
- Oct 2006
- Ames
Sebring Silver Metallic- 2000 z28 Camaro
i have same problem and the guy who installed my headers told me that mufflex and think it was called makes a clamp thingy that can fix it for about 40 bux....dunno if it works cuz i havent tried it. maybe somebody else will know wat to do 4 us
04-13-2007, 09:20 PM #3
THanks! I'll look around to see what I can find, because I would gladly pay $40.00 to fix it!
04-14-2007, 08:57 AM #4
You have to find the source of the rattle before buying something you may not need. Put the car on a lift with it running to find the rattle
exhaust rattle???
By bluefields88 in forum External EngineReplies: 10Last Post: 01-29-2009, 01:37 PM -
Help: exhaust rattle
By mr_r0bert0 in forum Camaro / SSReplies: 4Last Post: 10-15-2008, 09:25 AM -
exhaust rattle help please
By Bandit1 in forum External EngineReplies: 3Last Post: 02-20-2008, 02:48 PM -
exhaust rattle
By Vette LS-1 in forum CorvetteReplies: 2Last Post: 04-26-2006, 12:09 PM -
Exhaust Rattle!!!
By jeffsredt/a in forum Firebird / WS6Replies: 5Last Post: 03-20-2006, 03:44 AM
