    Member adham's Avatar
    Newport News, VA
    2000 Pontiac Trans Am
    rattling noise after header install
    after installing my headers and catted y-pipe i have been experiencing alot of rattling/clicking noise
    i went to the muffler shop and got the y-pipe welded to the catback because it was leaking
    now that is taken care of but i cant figure where the rattling is coming from
    the guy at the muffler shop said it was the cats
    he said they were broken from the inside or something
    they are brand new from MAC and came with the headers
    is this guy talking out his ass?
    i checked all the bolts and they are tight
    i dunno what is causing it
    has anyone experienced this before?
    PS: the cross-member that held the stock system together is not on because it will not fit
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    you'll have to look around under the car and see what's hitting where. header, y-pipe, etc... hitting frame, body, etc...have the exhaust shop put it on the lift and let you hear the cats for yourself. if they are, make sure it's not the heat shield on the cats rattling. if it is indeed the internals of the cats, call MAC.
    I Love My Bong easyericvan's Avatar
    Hot Springs, AR
    Midnight Blue
    99' Trans Am
    If its on the driver's side your y-pipe is probably hitting the heat shield. Mine was doing the same thing. I had a shop remove the heat shield where my y-pipe was hitting. If that doesn't work the bump stop hanger might fix it.
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    It may be a plain old exhaust leak...it sounds like a tick/click kind of noise that obviously increases with RPM. They may be leaking at the engine itself (perhaps a bad gasket or a bolt is backing out) or where the headers meet the y pipe...
    Newport News, VA
    i had the heat shield removed during the install
    no its not a ticking noise, did not mean to say ticking earlier
    it does not increase with rpm
    it is constant
    how will the hanger help me in this case?
    the system seems to be very sturdy/solid
    Hot Springs, AR
    Midnight Blue
    99' Trans Am
    It has a clamp that goes around the y-pipe. That hooks up to a support rod with 2 rubber bump stops in between that act kind of like shocks.
  1. Clunking/Rattling Noise in my T/A
    By Caelynne1724 in forum General Help
    Last Post: 04-14-2011, 05:59 PM
  2. Rattling/knocking noise
    By Mike99TA in forum Firebird / WS6
    Last Post: 03-24-2010, 09:59 PM
  3. Rattling noise, is it a cat problem????????
    By JwMonE99 in forum General Help
    Last Post: 11-16-2006, 05:21 PM
  4. knocking rattling noise
    By camarostripes96 in forum Internal Engine
    Last Post: 09-19-2006, 06:55 PM
  5. NOISE!!!! So Much Rattling!!!
    By boone94 in forum Firebird / WS6
    Last Post: 12-29-2005, 05:55 AM
