11-15-2006, 05:51 PM #1
Rattling noise, is it a cat problem????????
A while ago when I got my exahust done I got V-Force exhaust and took out my cat out casue it was a bad one. It sounds really nice when im driving but when i rev it up and it gets to about 3RPM somthing sounds like it is ratteling and its really loud. My best guest is that without the cat in im haveing too much free flow of air and its only a v6 with huge dual exhuast tips. Before i go outand bye another cat (right now I have a test pipe in) is there another reason why its doing that?
11-15-2006, 08:50 PM #2I went to Playboy Mansion
- Sep 2005
- Bakersfield/Long Beach Ca
YJ- 04 GTO M6
Maybe whoever put the exhaust in forgot to tighten a bolt or somethin?
11-16-2006, 04:00 AM #3
Check all of the hangers and ensure they are tight. A loose one might work fine under normal (below 2500RPM) driving but if you put a heavy load on the engine, things will begin to vibrate and a loose exhaust system is notorius for that. Also check any brackets/braces that were removed and then reinstalled when the exhaust work was done.
Mike
11-16-2006, 04:47 AM #4
Mine was rattling and found that my right tip was loose hitting the under body of car.
11-16-2006, 05:21 PM #5Member
- Oct 2005
- Houston,Texas
white- 2000 Camaro Z28
mine was doing the same thing, had mine at the dealer for a o2 sensor. so i told them of the rattleing noise it was making (Just like yours) and it was a loose at the manifold,
That was not covered under waranty and they charged me $50, It was worth it to me cuz I could not find where it was loose at. Dealers are not cheepMTI Clear Lid (Free Ram Air Mod Raised Air box) Larger MAF Ends,K&N Filter, SS Exhasut with cut out, rear Lower control arms,smooth bellows,[email protected] Dynoed 316 HP (Before RLCA and smooth bellows) 8.3.12 @86.86 1/8th mile 121,000 miles
Clunking/Rattling Noise in my T/A
By Caelynne1724 in forum General HelpReplies: 3Last Post: 04-14-2011, 05:59 PM -
Rattling/knocking noise
By Mike99TA in forum Firebird / WS6Replies: 4Last Post: 03-24-2010, 09:59 PM -
knocking rattling noise
By camarostripes96 in forum Internal EngineReplies: 0Last Post: 09-19-2006, 06:55 PM -
rattling noise after header install
By adham in forum External EngineReplies: 5Last Post: 01-06-2006, 07:55 PM -
NOISE!!!! So Much Rattling!!!
By boone94 in forum Firebird / WS6Replies: 10Last Post: 12-29-2005, 05:55 AM
