Results 1 to 15 of 15
Thread: LS Engines...which fit?
10-04-2008, 04:19 PM #1Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
I was talking cars with a guy at work and I happened to mention the new LS3 (the one that is in the ZR1, right?). Well, he asked if I would ever put that or an LS7 in my Trans Am and it got me thinking...do all of the LSx motors fit in my car?
I know the LS1 and LS2 do without any problems (direct bolt in), but what about the LS3 and LS7?
10-04-2008, 04:40 PM #2
the motors will bolt right in. PCM and harness changing for the LS3 and LS7 are in order.
10-04-2008, 04:57 PM #3
10-04-2008, 05:00 PM #4
the LS1, LS6 have the cam and knock sensors in the same location. the LS2 moved them. you can get a harness adapter for those. the LS3 and LS7 have a different reluctor ring on the crankshaft 52x instead of 36x. so the PCM will misinterpret the crank signal and not start.
10-04-2008, 06:28 PM #5
10-04-2008, 06:42 PM #6
All the same size. And by the way it's not an LS3 in the ZR1. It's an LS9. LS3 is in the standard c6 now.
10-04-2008, 06:44 PM #7
10-04-2008, 06:47 PM #8
10-04-2008, 09:21 PM #9
Yeah essentially the LS3 is the same as the LS9. I believe the compression is different and other little differences.
10-07-2008, 12:43 PM #10Senior Member
- Feb 2006
- Orange County, NY
Doesnt the LS7 run a dry sump system?
10-07-2008, 01:08 PM #11Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
10-07-2008, 02:36 PM #12
10-07-2008, 06:14 PM #13
10-07-2008, 07:21 PM #14
10-08-2008, 11:31 AM #15Senior Member
- Feb 2006
- Orange County, NY
I dont know.
Engines
By 024mula in forum LS2/LS3/LS4/LSxReplies: 9Last Post: 11-29-2012, 06:21 PM -
What engines
By Justin23454 in forum Firebird / WS6Replies: 3Last Post: 06-28-2010, 09:36 PM -
LS2 And LS7 Engines - Gen Four
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 12-18-2009, 09:40 AM -
LS engines
By manyponies in forum Internal EngineReplies: 4Last Post: 10-12-2009, 08:15 PM
