    Impwnded Smkn_TA's Avatar
    Davenport, Iowa
    Bright Red
    1999 Trans Am Ws6
    Ever Replaced the...
    Ever replace the coolant level sensor? Where is it at and anyone know the part # from gm? My brothers taurus the sensor for the windshield washer fluid went and the light stayed on nonstop, I assume it is similar sensor. because my level is correct and the line comes on and goes off with no pattern. I even added a little in case it was on the fence. If the sensor is hard to get to, I remove the light from the dash =) I know my level is right. Temp stays where it is supposed to. The radiator is filled to the top, and the overflow thing is right on the level it should be. SENSOR is definitly bad.
    Member Goldcuffs's Avatar
    Aug 2008
    Florida
    2000 Trans Am
    Look below the cap about 8 inches on the engine side. Square 2 wire sensor. Very easy to change.
    Member Mike's TA's Avatar
    Austin, TX
    99 Trans Am(sold)
    I need to replace mine also. I've taken it out and cleaned it and it's still messed up. I priced them and they run about $40 in my area. It's a fairly quick swap. IMO
    Member flipsutter's Avatar
    May 2008
    Arkansas
    1999 Firehawk
    I have replaced mine but the error light is still on. ;\
    Austin, TX
    99 Trans Am(sold)
    Well, that sucks. Now I'm wondering if something else is wrong.
    HELP!!
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    I havnt replaced mine, but I did knock it out when my battery came loose and smacked it out of the radiator. Some torque and a loose battery doesnt go well. It would be a very simple job. I put mine back in out on the road after I lost a few gallons of coolant.
    Yea, that was a good day.
  1. Need a Bulb Replaced?
    By BashamWS6 in forum Appearance Section
    Last Post: 12-25-2010, 10:53 AM
  2. Ls1 replaced with ls6.. Same height?
    By 5abivt in forum Internal Engine
    Last Post: 10-22-2010, 09:29 AM
  3. anyone had their cat(s) replaced under warranty
    By twozs in forum General Help
    Last Post: 04-17-2010, 05:35 PM
  4. PCV Valve Replaced, but..
    By RandomOmen in forum General Help
    Last Post: 06-03-2008, 05:08 PM
  5. The SS has been replaced......
    By pinky93 in forum Camaro / SS
    Last Post: 09-15-2006, 12:03 PM
