    Senior Member
    Toronto
    SOM
    2002 SS
    Ls1 replaced with ls6.. Same height?
    Just wondering if I'll need new pushrods Again if I go with ls6 heads and a mild cam... I just put crane rockers and new chromemoly pushrods in.
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    Depends on the cam, when you change out the lifters in the head swap they won't be the original size so you more than likely are going to have to change the pushrods again.
    Jun 2009
    coon rapids, MN
    2000TA
    get a eps cam with springs and push rods and make 430 rwhp.
    Bay Area
    my highbeams
    Quote Originally Posted by garygnu65 View Post
    Being a little vague aren't we?
    DFW
    '18 CTS-V
    '13 ZL1
    he doesn't need to change lifters. that's optional, not a requirement. i'm running stock lifters in my H/C car, putting down 460rwhp/410rwtq, with no issues.
    to answer your question, you may have to change the length of pushrods depending on the 'cc' size of the heads and what if at all they have been milled down (also, the thickness of the head gasket used). also, the cam size as well which depending on the specs of the heads you will need to check piston to valve clearance. call around get the answer from a professional in regards to your set-up you want to run, to see if you might need to change pushrod length.
    we don't have enough info to answer it with certainy.
  1. Question: height of LS6 Intake?
    By MudStainKILLA in forum External Engine
    Last Post: 08-14-2011, 03:23 PM
  2. Difference in height
    By pv-camaro in forum V6
    Last Post: 05-17-2010, 05:07 AM
  3. Sidewall height? HELP!
    By Speed_kills_WS6 in forum Wheels and Tires
    Last Post: 02-01-2009, 08:34 PM
  4. What's stock height?
    By Mr Z in forum Firebird / WS6
    Last Post: 09-08-2008, 03:38 PM
  5. tire height?
    By TedsB4Csled in forum General Help
    Last Post: 04-16-2008, 12:28 PM
