Results 1 to 3 of 3
Thread: Kicker CVT 6.5" Sub
09-26-2008, 06:03 PM #1
Kicker CVT 6.5" Sub
I have an 2002 WS6 with the monsoon system. The subs beside the rear seat from the factory have blown. The factory subs are a dual 4-ohm voicecoil sub. The kickers are a single 4-ohm voicecoil. Would the kickers be able to be wired in properly and load up right on the factory amp? would i use all 4 leads from the factory harness to connect the kicker? or just two of them and block off the other two?
sorry for all the questions but i have asked around and keep getting different answers. figured someone here would be more familiar with the monsoon and be able to direct me....thanks for your help!!
09-26-2008, 09:07 PM #2Junior Member
- Mar 2008
- Pittsburgh
Black- 2001 Camaro Z28
i actually was also wondering the same thing......i hear alot of good things about ED 7kv.2 but am a fan of kicker speakers in general. so +1 for any help
thanks,
Bill
09-27-2008, 08:19 AM #3Member
- Feb 2007
- austin
Black/Black- '00 Firebird WS6 T/A
Well, to the positive side you COULD wire it up with just 2, but unfortunately this will not give you sound equivalent to the factory because you will only have half the power your speaker needs to pump out copious amounts of deep bass along with the rest of your stereo. A lot of people put in an aftermarket deck and run the wires from the tweeters under the hatch to the sail panel and using the power of the deck (or amp, if you so choose) you can get good sound out of them but since they are subs in this case you probably want to LPF them somehow.
Hint: All four tweeters run directly off deck power. You can make this work but probably not with the factory deck.
98 Trans AM Kicker KS65 6.5"
By UC Warrior 1 in forum Stereo and ElectronicsReplies: 1Last Post: 11-25-2012, 10:52 AM -
Kicker 6.5" Subs
By McCool318 in forum Stereo and ElectronicsReplies: 10Last Post: 05-07-2008, 08:51 AM -
two 12" audiobahn immortals vs. 12" kicker solo x
By claytonr in forum Stereo and ElectronicsReplies: 7Last Post: 03-17-2008, 11:12 AM -
2 Brand New kicker L5 10" and 2 L7 12"
By cordezzy in forum Parts For Sale / TradeReplies: 6Last Post: 09-25-2007, 05:10 PM -
2 Brand New Kicker Solobaric L7's(12") For Sale (Selling Individually)
By JattGunMan in forum General ClassifiedsReplies: 0Last Post: 08-14-2007, 12:49 PM
