Thread: Rough Idle
    Sep 2008
    Huntersville, nc
    2001 Camaro z28
    Rough Idle
    I have had a 2001 Camaro z28 for about three years and now it is starting to idle a little rough. I have replaced all plugs and wires on the car and that helped the problem a little bit but it still idles rough. The car only has 25,000 miles on it now so i do not know what the problem is, any help on this would be great.
    Thanks
    Luke
    Feb 2006
    2002 WS6
    have you tried cleaning the MAF and IAC? Those seem to be the source of most rough idle problems, followed by a clogged fuel system.
    old timer blue02Z's Avatar
    2002 Z28
    ^^^i second that
    Sep 2008
    Huntersville, nc
    2001 Camaro z28
    What is best to way to clean the MAF and IAC
    Junior Member Getting Faster's Avatar
    Sep 2008
    Philly Burbs
    Murdered Out
    2003 Turbo Cobra
    Quote Originally Posted by z28llr View Post
    any auto parts store sells a maf cleaner spray...just don't touch the sensor.
    I went to Playboy Mansion FantaZGuy28's Avatar
    Bakersfield/Long Beach Ca
    YJ
    04 GTO M6
    Drive it more!
    But on a serious note, buy a can of BG44k and put it in with a full tank of gas and it should clean out all the fuel lines and everything the fuel touches, if that doesnt help then your SOL
    Member Goldcuffs's Avatar
    Aug 2008
    Florida
    2000 Trans Am
    Try cleaning the throttle plate. If you just did a full tune up you should do a crank relearn which is done with a scanner or you can simply unhook the battery for 10-15 minutes to accomplish the same thing.
  1. Rough Idle
    By thacher2189 in forum LT1
    Last Post: 02-19-2012, 03:04 PM
  2. Help: Rough Idle
    By 1WickedWS6 in forum GM Trucks
    Last Post: 01-04-2012, 08:16 AM
  3. Help: intermittant rough idle, off idle hesitation
    By Matto4785 in forum General Help
    Last Post: 09-21-2009, 06:12 AM
  4. Help: rough idle
    By RLamas in forum Firebird / WS6
    Last Post: 05-01-2009, 05:59 PM
  5. C5 Rough Idle
    By BlkNBlkC5 in forum Corvette
    Last Post: 04-14-2007, 07:42 PM
