Thread: Rough Idle
02-13-2012, 11:11 PM #1Junior Member
- Feb 2012
- Rolla, MO
Red- 1994 Z28
Rough Idle
1994 Camaro z28
head gasket had a small leak. Replaced both head gaskets, water pump and opti. Have everything back together now and I have what I think is a vacuum leak. When i start the car it revs to about 3000 RPM then drops back to a rough idle around 1000. Then when idling it'll randomly jump around up to 2000 and back down. Sounds like it has a mild cam in it. Brakes are really hard, like the booster isn't getting enough vacuum. I have replaced a couple vacuum lines on the manifold. Not sure what to do next, just runs like crap now.
02-14-2012, 11:57 PM #2
Something wasnt put back together correctly. Not much help I know, but it all has to be gone back over. Check all of your vacuum lines, all of the intake plumbing, and maybe scan the car and see what's happening when the car surges.
02-15-2012, 07:35 AM #3
Could it be a bad/dirty IAC or TPS?
02-19-2012, 02:04 PM #4Junior Member
- Feb 2012
- Rolla, MO
Red- 1994 Z28
I have it all back together correctly. My valves were too tight and it was leaking air internally. I adjusted everything right now and it idles at the right RPMs and all. However, it still idles rough and I think it is a miss. Whether it is my injectors, plugs, wires or ignition coil.. Im not exactly sure yet. I'm going to run a timing light through each cylinder using the arrow on the damper. I was just wondering if the car fires exactly at TDC for cylinder 1? I've heard that fires like 10 degrees before TDC, but I'm not really sure.
Help: Rough Idle
By 1WickedWS6 in forum GM TrucksReplies: 12Last Post: 01-04-2012, 07:16 AM -
Help: intermittant rough idle, off idle hesitation
By Matto4785 in forum General HelpReplies: 1Last Post: 09-21-2009, 05:12 AM -
Help: rough idle
By RLamas in forum Firebird / WS6Replies: 8Last Post: 05-01-2009, 04:59 PM -
C5 Rough Idle
By BlkNBlkC5 in forum CorvetteReplies: 1Last Post: 04-14-2007, 06:42 PM -
rough at idle
By Vette LS-1 in forum General HelpReplies: 6Last Post: 04-27-2006, 06:41 PM
