    The name says it all !!!FAST!!!'s Avatar
    Manlius, Il.
    2000 WS6, 2006 G35
    Bleeding the clutch help.
    I now consider myself an expert in replacing my clutch due to the fact that I had to do it several times to get it right. Now here's the new problem...bleeding. God knows I cut myself about a gajillion times while changing that clutch (mechanix gloves save lives) and bled gallons of my blood. But I mean bleeding the clutch...
    So I put the trans in, bolt everything up, and set up to bleed it. Thats when I noticed that the bleed screw is at about the 10 o'clock position, is a 11mm fitting, sits flush with the trans casing, and has about 3/4 to 1" of space between it and the firewall (is that area still considered a firewall?) Anyway...How the F**K am I supposed to get any kind of line on that huge fitting with no space and still have room to fit a wrench in there to turn it? Also what kind of wrench am I supposed to use? The car runs fine, the clutch works properly, and when you depress the pedal and let it out it extends fully but the friction point is pretty close to the floor and it is really soft. Any help is greatly appreciated.
    Junior Member jc99ls1ss's Avatar
    Louisiana
    Bright Red
    1999 Camaro SS
    1/4" drive ratchet and socket to fit. No need for a line just let it run down into housing and out weep hole.
    allenhurst GA
    onyx black
    1999 formula firebird
    what he said/...just make sure its a good 1/4 drive ratchet that wont flip back on you...cause that $hit sucks..
    Member edbird's Avatar
    hammond Ind
    1999 trans am convert
    I have not had to do this yet but the GM Tech bullitin makes it sound easy.
    Document ID# 1550985
    1999 Pontiac Firebird
    Info - Improved Bleeding Procedure for Hydraulic Clutch Release System #01-07-31-002A - (Sep 22, 2004)
    2005 and Prior Passenger Cars and Light Duty Trucks
    2005 and Prior Chevrolet and GMC 6-7F T-Series Medium Duty Tilt Cab Models
    2005 and Prior Isuzu F-Series Medium Duty Tilt Cab Models
    This bulletin is being revised to add model years. Please discard Corporate Bulletin Number 01-07-31-002 (Section 07-Transmission/Transaxle).
    This bulletin is being issued to inform dealers of an improved procedure to aid in the ease of bleeding the clutch hydraulic system for the above listed vehicles. This procedure can be used anytime air is introduced into the hydraulic system. Following this procedure may also reduce the number of unnecessary parts replaced for low clutch pedal reserve and high shift effort.
    Verify that all the lines and fittings are dry and secure.
    Clean the dirt and grease from the reservoir cap in order to ensure that no foreign substances enter the system.
    Remove the reservoir cap.
    Fill the reservoir to the proper level with the required fluid.
    Attach the J 43485 (Adapter) to the J 35555 (Mity Vac) or equivalent.
    Important
    Brake fluid will deteriorate the rubber on J 43485. Use a clean shop cloth to wipe away the fluid after each use.
    Place and hold the adapter on the reservoir filler neck to ensure a tight fit. In some cases, the adapter will fit into the reservoir opening.
    Apply a vacuum of 51-68 kPa (15-20 hg) and remove the adapter.
    Refill the reservoir to the proper level.
    Repeat Steps 6 and 7.
    If needed, refill the reservoir and continue to pull a vacuum until no more bubbles can be seen in the reservoir or until the fluid level no longer drops.
    Caution
    The vehicle will move if started in gear before the Actuator Cylinder is refilled and operational. Start the vehicle the first time in neutral to help prevent personal injury from vehicle movement and see if the transmission will shift easily into gear.
    Pump clutch pedal until firm (to refill actuator cylinder).
    Add additional fluid if needed.
    Test drive vehicle to ensure proper operation.
    GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
    WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
    © Copyright General Motors Corporation. All Rights Reserved.
    Junior Member Acceleration Junky's Avatar
    Long Island, N.Y
    sunset metallic orange
    2002 Z28
    I cut a hole in the trans tunnel so that I can access the bleeder valve from inside the car. I'm glad I did that because my original plan of using just the mighty vac wasn't good enough. I bleed it with a mighty vac first, and was satisfied with it. But just to make sure, I decided to crack the bleeder valve on the slave too. I was surprised that there was still air in the system when I opened it.
  1. bleeding t56 clutch
    By mikey gavin in forum Manual Transmission
    Last Post: 01-17-2011, 08:41 AM
  2. Clutch bleeding...
    By Black02LS1 in forum Western Members
    Last Post: 04-17-2007, 09:07 PM
  3. HELP!!!Bleeding Clutch
    By Jayh in forum Manual Transmission
    Last Post: 10-16-2006, 12:36 PM
  4. Bleeding the Clutch
    By steve01 in forum Manual Transmission
    Last Post: 06-03-2006, 04:44 AM
  5. Bleeding clutch ????
    By GMW-CSL in forum General Help
    Last Post: 10-19-2005, 11:24 AM
