Results 1 to 20 of 35
Thread: bleeding t56 clutch
01-13-2011, 07:28 PM #1
bleeding t56 clutch
so i put a new slave in my t.a. got it all back in there i figured i would have to bleed the hydraulics but i pushed the pedal anyway and it popped right to the floor and only came back about a inch. u have to pull it back to get it to pop back up just like it did going down i tried bleeding it with a friend in the car to push the clutch in and out while i opened the bleeder we did it about 20 time and made no difference idk what to do can any one help me to find an easy way to get her done?
01-14-2011, 03:21 AM #2
Did u add brake fluid...?
01-14-2011, 03:51 AM #3Senior Member
- Apr 2008
- Madison, WI
There's a sticky for that
How to bleed a clutch
01-14-2011, 07:53 AM #4
yeah i kept it full the whlole time
01-14-2011, 07:55 AM #5
yeah i read all that but i have no mity vac and i have to have it done and out of there today
01-14-2011, 11:14 AM #6
I have the mity vac, but I still prefer to bleed the clutch differently.
I first remove the clutch hydraulic line from the trans. It doesn't leak fluid unless it's depressed with a small screw driver.
I'll depress it and let it gravity drip into a container. Replenish the reservoir as necessary. It only takes a couple of quick attempts. This will guarantee all of the air is removed from this half of the system (from the line on up through the cars master cylinder)
Simply plug the line back in. From here the only air left in the system would be the slave inside the bell housing, which will be a very small amount of air. All you have to do at this point is pump the clutch a few times and crack the bleeder for a second. You can also use your mity vac at this point and keep this operation to one person.
From all the times I've done this it only takes a couple of times and you're done. Very simple, takes about 5 minutes.
It's difficult to bleed the system from the start without removing that line as I described above. Trying to pump the pedal will result in what you are experiencing with a stuck pedal on the floor.
My method eliminates that hassle, and you'll have some pedal effort right away just from the line trick I mentioned, makes it very easy to pump and remove the remaining air from the slave at that point.Last edited by Firebirdjones; 01-14-2011 at 11:17 AM.
01-14-2011, 11:33 AM #7
when u say to depress it do u mean the thing in the slave or in the line it self
01-14-2011, 12:17 PM #8
Go buy a mityvac and have it done in 30 seconds.
01-14-2011, 12:27 PM #9
01-14-2011, 12:34 PM #10
ok cool dont sound bad
01-14-2011, 02:54 PM #11
Yep, piece of cake. Even if you have a mity vac, I'd still recommend this procedure first, it removes most of the air before you even start the bleeding process.
After that it's just a few pumps of the pedal and crack the bleeder if you have a helper. Twice doing that should be enough, and you don't even get the mity vac dirty
01-15-2011, 07:26 AM #12
idk if i get what u mean about bleeding the line. the fluid runs out and then it starts to drip but once i close it and open itback up it has a stream again if i keep holding it open it starts to drip again.. so what i did was open it a few times just long enough so it wouldnt drip and closed it then i put the line back in had my friend go to pump it and i bleed it, it was the same thing as last time the pedal stuck to the floor
01-15-2011, 10:19 AM #13
Are you filling the right reservoir? I have a seperate reservoir for the clutch fluid. It's smaller and right next to/behind the master.
01-15-2011, 11:52 AM #14
01-15-2011, 12:36 PM #15
I never tried it without the mity vac. You can't loan it out from a supply store like Napa or whatever? It is so easy it should be a crime. You gotta have one. I just flushed and bled my brakes a few weeks ago. Peice of cake.
01-15-2011, 12:55 PM #16
idk if they will i would see but theyre closed
01-15-2011, 07:52 PM #17
I've never known any of the stores to loan them out. They cost about ~$50 give or take if my memory serves.
I do like to use it for brakes since there is alot of bleeding to do in that respect.
01-16-2011, 12:02 AM #18
thats just it 50 is a lot for that
01-16-2011, 07:04 AM #19
Yes it is, and for as simple as it is to bleed the clutch it's not worth the investment.
Now if you owned several cars and bled brakes or flushed brake systems a few times a year then it's worthwhile to have the kit.
I have seen them on sale from time to time if you keep an eye out.
01-16-2011, 07:20 AM #20
50$,? the loaner macpherson strut tool from NAPA is ~100.
Bleeding the clutch help.
By !!!FAST!!! in forum Manual TransmissionReplies: 4Last Post: 09-23-2008, 04:21 AM -
Clutch bleeding...
By Black02LS1 in forum Western MembersReplies: 12Last Post: 04-17-2007, 09:07 PM -
HELP!!!Bleeding Clutch
By Jayh in forum Manual TransmissionReplies: 10Last Post: 10-16-2006, 12:36 PM -
Bleeding the Clutch
By steve01 in forum Manual TransmissionReplies: 3Last Post: 06-03-2006, 04:44 AM -
Bleeding clutch ????
By GMW-CSL in forum General HelpReplies: 2Last Post: 10-19-2005, 11:24 AM
