    Central PA, USA
    1995 Trans Am 6 Speed
    Panhard Rod Adjustable vs. Non-Adjustable
    Have a stock 1995 Trans Am with 105K miles. Its time to freshen up the suspension system. Considering upgrading the Panhard Rod to take advantage of the harder poly bushings. Have a question as to what advantages does an adjustable Panhard Rod have over non-adjustable. Plus what is the adjustablity buy in a stock configured F-Body?
    If an adjustable is better, what is the criteria for ajusting it?
    Considerng a suspension package from Hostchkins which only comes with an adjustable rod. Edelbrock makes a non-adjustable one that is on my list.
    Will be making the upgrade in conjusting with replacing the lower trailing arms by Hostchkins. Also looking at replacing the front and rear sway bars with the larger Hotchkins sway bar (sold as a package.)
    The rest of the TA is being kept stock with no power mods planned.
    Comments please.
    St. Clair Shores. Michigan
    `98 Formula M6 HdTp
    Give Sam Strano a call he's a Site Sponsor and is the Ultimate F-body Suspension guy.
    I have his Springs Swabars and Koni 4/4's and I couldn't be happier.
    As for your panhard bar question Adj. vs Non Adj.
    All Factory F-bodies have the rearend biased to the driver side meaning it is not centered. Using an Adjustable Panhard bar you can shorten the length and move the rearend over towards the right. Same idea applies if you ever plan on lowering the car. I would suggest an on car adjustable one.
    Craig
    Semi Retired Street Racer
    Gone but not forgoten
    NBM `98 Formula M6 HdTp
    1 of 1 Build Date 3/12/98
    Hamburg, Germany
    1998 Camaro Z28 A4
    i have the edelbrock non adjustable, works fine for me. definitely a gain compared to the stock one.
    Marylandistan
    2001 Trans Am (sold)
    I noticed no difference in ride with my adjustible rod ended phb. Get the adjustable one, no reason to change it otherwise imo.
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    I agree unless you are lowering the car don't bother. When you do then get an adjustable.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Im considering on getting an aftermarket one just for the fact that the stockie hits my exhaust when the suspension is traveling. Probably getting a non adjustable
    Central PA, USA
    Thanks folks. Will be call Mr. Strano this week to discuss. Will report back with my findings.
  1. Question: Adjustable Panhard Bar
    By 01WS6 in forum Suspension and Handling
    Last Post: 12-18-2010, 04:48 AM
  2. Adjustable Panhard Bar
    By 2001camaroSS in forum Suspension and Handling
    Last Post: 12-14-2010, 07:49 PM
  3. Adjustable Panhard Rod Question!!!
    By L3THAL_Z28 in forum Suspension and Handling
    Last Post: 07-26-2007, 05:20 PM
  4. adjustable or non adjustable panhard?
    By Z28LS1 in forum Suspension and Handling
    Last Post: 03-12-2007, 02:07 PM
  5. WTB: Non-adjustable panhard bar
    By Warbird in forum Parts Wanted / Trade
    Last Post: 09-23-2005, 10:15 AM
