Results 1 to 20 of 43
Thread: Adjustable Panhard Bar
11-16-2010, 04:56 PM #1Senior Member
- Feb 2010
- Greenwood, IN
Light Pewter Metallic- 2001 Camaro SS
Well since I'm lowered with the Eibach Prokit it's probably time to think about getting a adj. panhard bar. What should I get? I don't know much about these things so any input helps. Thanks guys
11-16-2010, 05:28 PM #2King 0f n00bz
- Jan 2006
- Shepherd, Michigan
umi single adj. on car. and use the roto joints
11-16-2010, 05:44 PM #3
^^ Agree.
11-16-2010, 06:32 PM #4Senior Member
- Oct 2008
- Coral Springs, Fl
Haven't tries the roto joints
I have polys and like them but have heard great things about the roto joints
Dont get the spherical rod ends, they're noisy as hell
11-16-2010, 08:10 PM #5
11-16-2010, 08:11 PM #6Senior Member
- Oct 2008
- Coral Springs, Fl
Check KY speed
UMI makes great stuff
11-16-2010, 08:18 PM #7Senior Member
- Feb 2010
- Greenwood, IN
I didnt realize UMI was a sponsor here. http://www.umiperformance.com/catalo...roducts_id=357 is this what i need?
11-16-2010, 08:28 PM #8Senior Member
- Oct 2008
- Coral Springs, Fl
Yes they are but you can get the UMI stuff from KY Speed
11-16-2010, 08:30 PM #9
11-16-2010, 08:32 PM #10
11-16-2010, 09:15 PM #11
11-16-2010, 09:22 PM #12
11-16-2010, 09:52 PM #13
11-17-2010, 03:26 AM #14
Getting the torque arm off the back of the transmission is a good thing. For the strip you would want to consider a tunnel mount. However, it tends to be a bit noisier than other setups and in extreme braking wheel hop is possible. Check out the other styles on UMI's website. Just be sure it is going to be compatible with your current (and possibly future) exhaust systems.
11-17-2010, 05:44 AM #15
If your car is lowered, then your TA pinion angle is probably off. Lowering the car changes the suspension geometry.
You "should" get an adjustable TA and also relocation brackets for your lower control arms if you don't have them already. Your instant center needs to be brought back to the correct position.
Also, with a lowered car now, that PHB is probably not going to be parallel to the ground when your suspension is loaded. You want the PHB to be as parallel to the ground as possible for the way that it works. If you see yours isn't because of how much you're dropped, you might also want to look into the relocation kit for it.
It's never easy or cheap
11-17-2010, 08:11 AM #16
11-17-2010, 08:50 AM #17King 0f n00bz
- Jan 2006
replied btw.
ok well now that you are lowered..you need or should..depending on who you talk to...replace all non adjustable rear suspension pieces. so the list goes (using umi stuff..which i strongly suggest)
adjustable lower control arms with roto joints
here
lower control arm relocation bracket
here
adj. panhard bar ON CAR ADJUSTABLE!!!!! with rotojoints
here
adj. torque arm (this requires some thought tho..you need to figure out what you want from the car...if you are into hpe and or autox get the long arm torque arm with the relocation bracket. if you are heavy into drag racing then the short arm kit is your cup of tea...if you are a weekend warrior with a little of both..it is up to you on your tolerance of road noise and vibration)
a optional buy is the panhard relocation bracket ..this one is really up to you..a added benefit is the ability to run larger exhaust pipe out the back with the relo bracket
here
11-17-2010, 09:16 AM #18
11-17-2010, 09:23 AM #19King 0f n00bz
- Jan 2006
well remember when you lower..you not only change its horizontal orientation but also its longitudinal and depth also...
with what you just put as a street cruiser..nvh is a big concern. so stay with the long arm. and the relocation if you want..but as you wont be launching it is up to you...id still watch that tailshaft of yours tho if you dont relocate.
a adj panhard is still needed and at least the lca relocation bracket also.
i DD my car and suspension wise it is completely fine..my exhaust on the other hand hangs low and is resting on my k member which drives me crazy.
but my car is incredibly fun to drive..especially around curves and even launching
11-17-2010, 09:31 AM #20
Question: Adjustable Panhard Bar
By 01WS6 in forum Suspension and HandlingReplies: 6Last Post: 12-18-2010, 04:48 AM -
Panhard Rod Adjustable vs. Non-Adjustable
By seppburgh in forum Suspension and HandlingReplies: 6Last Post: 09-22-2008, 04:18 PM -
adjustable or non adjustable panhard?
By Z28LS1 in forum Suspension and HandlingReplies: 3Last Post: 03-12-2007, 02:07 PM -
Adjustable Panhard Rod wanted: 98 Z28
By smkeater911 in forum Parts Wanted / TradeReplies: 0Last Post: 02-03-2006, 08:09 PM -
WTB: Non-adjustable panhard bar
By Warbird in forum Parts Wanted / TradeReplies: 2Last Post: 09-23-2005, 10:15 AM
