Results 1 to 16 of 16
Thread: MDF stealth enclosure
09-16-2008, 09:37 AM #1
- Jul 2007
- UK
black- 2001 ws6
Hi,
I want to mount a 10" sub in the drivers side cubby hole.
Shipping costs and duty mean importing a custom made F body stealth box is Very expensive.
I have never built a sub box before, but I am a competent woodworker.
My lack of fiberglassing skills makes me want to construct a box from MDF.
Have you got any pointers or a write up? I know it should be airtight, so do I need to seal up the joins with something special?
How do I fix it in place to stop it moving around when I'm driving?
How do I attach the carpet, glue / staples??
Any tips / pointers are appreciated
Many thanks,
Paul.
09-16-2008, 09:56 AM #2
- Oct 2007
- Muncie, IN
00 TA PWTR, 98 VertTA NBM- 80 TA BLK, 80 Formula NBM
i just used 3/4" osb (i think partical board or actual plywood would have been a better choice), screwed it together with drywall screws, and sealed it up with kitty hair, but im sure you could just use some kind of caulking.
as for it stayin in place, i never did anything for this. the lip of the inside quarter plastic trim holds it in place just fine.
as for carpet, i got it at the local stereo store and just glued it on.
the one tip i have for ya, is to fill the box with polyfil. it helps prevent distortion.
09-16-2008, 10:29 AM #3
- Jul 2007
- UK
black- 2001 ws6
Hi,
Thank you for your reply.
Not herd anything about caulking, is that like silcone for the joins?
Do you mean I should fill the screw holes with polyfil?
I just read a good write up for two 12"s, and noticed the terminal that goes through the box. Could you divulge more info on what I need to do please?
Many thanks,
Paul.
09-16-2008, 10:47 AM #4
- Oct 2007
- Muncie, IN
yeah just silcone the joints
polyfil is like the stuffing out of a stuffed animal. you would fill the whole box full before place your sub in it.
i didnt get very fancy here. my speaker wire goes from the speaker through a caulked hole in the box directly to my amp. i would just ask at your local stereo store what they have available
09-16-2008, 11:32 AM #5
- Jul 2007
- UK
black- 2001 ws6
Great, thanks for helping out a newbee.
Much appreciated
09-16-2008, 11:41 AM #6
- Oct 2007
- Muncie, IN
no prob
09-16-2008, 11:41 AM #7
yah--speaker terminals can be purchased for cheap from the stereo store. cut a hole in the box to place the terminal cup in, and screw in into place.
09-16-2008, 11:42 AM #8
09-16-2008, 02:28 PM #9
- Feb 2006
- Orange County, NY
Make sure you predrill all of your holes for the screws and use course thread screws. Any caulk or slicone will work. Just seal up the seams after it is put together. For the carpet spray adhesive works good for the visible part, I staple the edges where you won't see it to help hold it in place.
09-16-2008, 03:22 PM #10
- Jul 2007
- UK
black- 2001 ws6
Great, thanks for the advise.
09-16-2008, 05:16 PM #11
09-25-2008, 06:25 PM #12
just make sure your cuts are straight and use elmers wood glue it bonds the to pieces of wood together (if you use mdf) I have run 3500 watts in to a box that was just glued and never broke anything
09-26-2008, 03:26 PM #13
[QUOTE=UKRAMAIR;1639589]I just read a good write up for two 12"s, and noticed the terminal that goes through the box. Could you divulge more info on what I need to do please?[QUOTE]
Umm...
I probably sound like a dumbass here but...
That sounds like you want 2 12's now? 12's aren't to stealthy.
09-27-2008, 08:19 AM #14
- Jul 2007
- UK
black- 2001 ws6
Yes, I worded that badly, sorry.
I ment to say, I have seen a build up of a box for 2 12" subs, and I guess the same construction process (Glue, chalk, lap, thickness of timber etc) will apply to my 1 10" stealth box.
Sorry for the confusion, I think I am a bit more aware of what I should be doing now.
09-30-2008, 04:39 AM #15
10-08-2008, 03:59 PM #16
MDF board for the win
Wanted: Stealth Sub Enclosure
By IH8EVRY1 in forum Parts Wanted / TradeReplies: 1Last Post: 06-25-2010, 07:34 PM -
Wanted: stealth enclosure sub box
By SteveCZ28 in forum Parts Wanted / TradeReplies: 3Last Post: 05-06-2010, 03:40 PM -
Stealth enclosure sub.What are you using?
By Red97LT1 in forum Stereo and ElectronicsReplies: 2Last Post: 03-11-2010, 10:14 PM -
IDQ v.3 or RE Audio SE-10 in Stealth Enclosure
By Red97LT1 in forum Stereo and ElectronicsReplies: 4Last Post: 03-01-2010, 04:27 PM -
where can i find a 12 stealth sub enclosure
By imthe420dan in forum Stereo and ElectronicsReplies: 1Last Post: 03-10-2006, 04:56 PM
