Results 1 to 2 of 2
    imthe420dan
    Guest
    where can i find a 12 stealth sub enclosure
    im looking for a 12 stealth sub enclosure that will fit into the nitch on the drivers side of my camaro. i see a ton of 10 in stealth boxes but no 12's. anyone out there have any suggestions...
    Feb 2006
    Marietta GA
    Mystic Teal Metallic 79U
    1998 Pontiac Trans Am
    Subthump USED to make them but stopped. You might be able to email them and inquire about having one made. You may be able to use one of their 10in. and cut out the hole to fit a 12in. but airspace will be slightly comprimised. Airspace in their 10in. is .6 cu.ft. Alot of the 12in. subs I've seen require about .75 cu.ft. (figures are for sealed enclosure). Your not giving up that much. You may have to notch out the plastic a bit for the sub to fit in the hole. Check with www.fbodyaudio.com and search around a bit. You may find something there. www.subthump.com where alot of guys get there enclosures also. Very high quality. Good luck.
  1. Wanted: Stealth Sub Enclosure
    By IH8EVRY1 in forum Parts Wanted / Trade
    Last Post: 06-25-2010, 08:34 PM
  2. Wanted: stealth enclosure sub box
    By SteveCZ28 in forum Parts Wanted / Trade
    Last Post: 05-06-2010, 04:40 PM
  3. Stealth enclosure sub.What are you using?
    By Red97LT1 in forum Stereo and Electronics
    Last Post: 03-11-2010, 11:14 PM
  4. IDQ v.3 or RE Audio SE-10 in Stealth Enclosure
    Last Post: 03-01-2010, 05:27 PM
  5. MDF stealth enclosure
    By UKRAMAIR in forum Stereo and Electronics
    Last Post: 10-08-2008, 04:59 PM
