Results 1 to 17 of 17
    AZ.
    2002 Trans am
    02 trans am transmission issue
    driving at 60 or so, (low rpm) for a few miles my trans mission seems to slip or lose traction. ie the rpm's jump but no speed increase. I then down shift from D to 3, and back to drive and it is ok. only happens on the highway. I can floor it and it will down shift.
    denton,Texas
    hey
    Sounds to me like your loseing lock up...Hope this helps Dave
    Member performabuilt's Avatar
    SUGAR LOAF PA
    blue
    2000ss
    Sounds like as he said your loosing lockup probably due to engine missfire
    AZ.
    2002 Trans am
    lockup
    if the cause is that the tc is un locking. live with it or get a new TC
    Sep 2008
    West Lafayette, IN
    2000 Trans AM WS6 Conv
    Question Mine too!!!
    yo dude! mine is doing the exact same thing! i've only noticed it on the interstate around 70ish MPH and it'll kinda loose power, but its really smooth and not jerky or anything. the RPMs will go up between 2500-3000 and its not stable and then it might kick back into gear and run at normal 2100 RPM... its really odd. I took it in and the guy thought it was the valve body of the transmission so he replaced that part ($450) and its still doing it (although its not as frequent now)... he thought the next step would be to rebuild the transmission which is $1800... did you ever find out any more info about ur car dude? i'm curious to see what they say about yours..
    AZ.
    2002 Trans am
    Transmission
    I had my transmission rebuilt two months ago. Shift kit putin and still the same problem.
    SUGAR LOAF PA
    blue
    2000ss
    if it locking and unlocking due to engine missfire neither a shift kit nor converter will help and converters do not lock and unlock randomly on there own, You can either correct the missfire or in cases of moded engine and or high stalls you will need to raise the missfire tables in tuning
    AZ.
    2002 Trans am
    transmission
    Quote Originally Posted by performabuilt View Post
    Are you saying that the engine is missfiring, like a bad plug, because there are no codes coming up.
    Member DemonSpeed's Avatar
    Virginia
    Pewter Metallic
    1999 Trans Am
    i have been having a similar problem as well, just seems to unlock. It's mostly at highway/interstate speeds and seems pretty random. I can put it in neutral or 3 and back in D and it clears up for a while. This has been happening for quite a while, though dont think its a misfire in my case. It happened on my ls1 and now its happening with my new ls6 in. what else could cause this?
    LS6 Engine swap, Custom Predator Tune, Lid, SLP Cold Air, Ram Air H.O. Hood, Hooker Long Tubes, !Cats, 3" True Duals w/Dynomax Bullets, Performabuilt stage 2 w/3600 stall, B&M Trans. Cooler, Moser 12 Bolt w/ 3.73's
    Pics of my car
    http://community.webshots.com/user/demonspeed_ta
    denton,Texas
    hello
    Is this a stock transmission? Try adding a qt of atf, yes over fill it by a qt. Next if it's a stocker.....the best thing to do is put it on a scanner and watch to see if it's being called for.(the unlock that is) If not then you've isolated that it's happening either mechanical or hydraulic, in other words inside the trans.....have the lock up valve changed with either a sonnax or my preference is the transgo valve... hope this helps Dave
    Sep 2008
    West Lafayette, IN
    not a misfire..
    yeah i don't think its a misfire. the engine is still running smooth, it just that it seems to start slipping. I haven't rebuilt my transmission and everything on my LS1 TA is factory. Anyone let me know what they've figured out cause it gets kinda annoying.
    I too can slip it down to third and the problem will go away for a while and then gradually start in again. Thanks guys! HELPP!!!!
    Virginia
    Pewter Metallic
    1999 Trans Am
    well mine is getting worse, hardly locks up at all now. You think my converter has gone bad? Yfuddo, any news on your issue?
    Feb 2006
    2002 WS6
    Probably just the lock up solenoid getting stiff.
    Virginia
    Pewter Metallic
    1999 Trans Am
    what can you do about that?
    Member GNICTRY's Avatar
    Virginia
    2000 Trans Am WS6 Ram Air
    i had this happen for a week then lost 3 n 4 on way home...4k at 40 mph was my max...sucked with lm1...
    n e ways i bought a used rebuilt 02 trans and stall and its fine
    it was either my shift solenoids or my convertor..more like my convertor cause it did hang in gear just didnt have them
    Member devil6rr's Avatar
    NJ
    SOM / NBM
    2002 Pro Z28/2001 TurboTA
    Quote Originally Posted by bryce5_04 View Post
    +1 on that my 02 A4 does the same thing lately very annoying im gonna talk to performabuilt soon about a level 2 cause come NOV im boosting!!
    Sep 2008
    West Lafayette, IN
    Yeah... i still haven't figured out what the problem is exactly... i'm kinda just suffering through it right now til i graduate college... i don't have any money right now to fix the issue.. if you get your performance transmission, def let me know how it is... cause i'd def be interested in doing that if i had to replace my trani...
  1. 2003 VY SS Auto transmission issue
    By PedroWilsoni in forum General Help
    Last Post: 04-13-2011, 04:22 AM
  2. transmission issue
    By EasyEp in forum GTO
    Last Post: 10-15-2009, 03:00 PM
  3. Clutch, or Transmission issue, not certain!!!?!?!
    By Twizz in forum Manual Transmission
    Last Post: 09-08-2009, 09:46 AM
  4. Transmission or Fuel issue?
    By jamessr in forum General Help
    Last Post: 09-02-2007, 04:26 PM
  5. Have a transmission issue
    By 04QSMGTO in forum Manual Transmission
    Last Post: 04-26-2007, 09:17 PM
