Results 1 to 1 of 1
Thread: Have a transmission issue
04-26-2007, 09:17 PM #1Junior Member
- Apr 2007
- JACKSONVILLE FL
SILVER- 2004 GTO
Hello all I have got a problem with my 04 GTO with 18,400 miles on the clock. I have started to notice a sound when the car is in neutral. It sounds like a wirling sound and it is very faint. I can't notice it outside of the car. If I press the clutch pedal in it will fade away. I am hoping my extended warranty will cover the problem. From reading the fine print it will cover only lubricated parts and will not cover the clutch or throw out bearing. After doing some research online I am pretty sure it could be a bearing problem but which one? I don't think it is a throw out bearing because if it was I would be hearing a noise when I press the clutch pedal in. Has anyone of you had a simular problems? And what other bearing could it be? Or could it even be something else? I could really use your imput!
issue with grinding noise from transmission
By bezerker03 in forum Manual TransmissionReplies: 1Last Post: 12-01-2010, 07:28 PM -
transmission issue
By EasyEp in forum GTOReplies: 2Last Post: 10-15-2009, 03:00 PM -
Clutch, or Transmission issue, not certain!!!?!?!
By Twizz in forum Manual TransmissionReplies: 2Last Post: 09-08-2009, 09:46 AM -
02 trans am transmission issue
By yffudo in forum Automatic TransmissionReplies: 16Last Post: 10-23-2008, 07:49 AM -
Transmission or Fuel issue?
By jamessr in forum General HelpReplies: 3Last Post: 09-02-2007, 04:26 PM
