    Rancho Santa Margarita, CA
    2002 Trans Am
    Bilstein HD shocks vs SLP Bilstein Ultra shocks
    Is there a difference between the Bilstein HD shocks and the SLP Bilstein Ultra shocks?
    Thanks,
    Jim
    Member Fastcar's Avatar
    Jersey Boy
    Dark blue metallic
    2000 TransAm
    I have the SLP Bilstein shocks, the ones from the "Bilstein" package. SLP claims that the shocks are specially valved to their specs by Bilstein and are actually 'softer' than Bilstein's normal HD shocks. They claim that softening the valving slightly helps increase the suspension compliance which will give you better handling. Obviously I can't compare the SLP shocks with Bilstein's standard HD's but I can tell you they're far better than the factory shocks both in handling and ride.
    2002 Trans Am
    Thanks for the info.
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    the slp's are vavled to go with the slp springs on the SS and firehawks. they lower the car i believe and since the HD's arent made for lowered cars, SLP just had them revalved.
    Senior Member GottaHaveLS1's Avatar
    Connecticut
    1999 Trans Am M6
    So does that mean that the blistein Hd shocks cannot be used with lowering springs? I was looking to use those shocks and bmr lowering springs but i havent bought anything yet...
    Jersey Boy
    Dark blue metallic
    2000 TransAm
    Quote Originally Posted by GottaHaveLS1
    No, it's not the shocks that can't be used but the fact that the valving of the shocks might not be right for your springs. Ask Sam Strano. The shock manufacturer takes into account the amount of total suspension travel that's built into your car. When the car bottoms out, it'll hit the bump stops and that's as low as she'll ever go normally. Shocks aren't designed to be suspension stops. If your car bottomed out and the shocks stopped the undercarriage from contacting the pavement you'd be looking at a lot of expensive repairs. The real world ain't no "Fast & Furious" - that BS only happens in the movies.
  1. Question: difference between bilstein hd and bilstein shocks
    By jonnyman in forum Suspension and Handling
    Last Post: 03-08-2013, 12:13 PM
  2. edelbrock or bilstein shocks?
    By carcrazy9716 in forum Suspension and Handling
    Last Post: 03-28-2007, 02:15 PM
  3. Bilstein shocks
    By benoh in forum Parts Wanted / Trade
    Last Post: 12-19-2006, 05:27 PM
  4. Kyb Agx Or Bilstein Shocks?????
    By BlackZ28629 in forum Suspension and Handling
    Last Post: 09-17-2006, 09:53 AM
  5. bilstein shocks
    By AnToN in forum Suspension and Handling
    Last Post: 03-14-2006, 07:49 PM
