Results 1 to 20 of 24
    Feb 2007
    buffalo, ny
    blue
    2000 pontiac trans am
    edelbrock or bilstein shocks?
    bit of a newbie question but does anyone know which shocks are better... without sacrificing ride comfort the edelbrock performer ias shocks or the bilstein sport shocks... from my understanding the edelbrock front shocks are better than the bilsteins but the bilstein rear shocks are better than the edelbrocks would it be recomended to mix and match?
    Bilstein HD hands down are a far better damper for our cars.
    Jun 2002
    Montreal, CANADA
    triple-black
    2000 CamaroSS convertible
    i'd get the Bilstein HD on stock springs.
    Eugenio_SS
    Member rickssz's Avatar
    Feb 2006
    pgh
    Are the bilsteins softer or as firm or stiffer than SSZ shocks and what % is the rebound rate?
    Hamburg, Germany
    1998 Camaro Z28 A4
    i just switched from stock to bilstein hd (with stock springs), and it's like a miracle. also, bilstein has a special valving that prevents the oil in the damper from foaming, meaning they keep working well on bad roads and heat.
    WI
    Blog Entries
    1
    09 EclipseGT 75 Chevy 4x4
    2001 Trans-Am 13 F-XT
    Bilstein for the win! I'd rather go with the Koni's though. I'm running KYB AGX just due to the price and being adjustable.
    Parkton MD
    2002 Z28
    The Bilsteins made a huge improvement over my stock shocks, I have the stock springs, and my car rides and handles great. No side step on bumps, limited body roll, and comliant ride.
    silver2002Z
    Guest
    if u can afford them get adjustable konis......$200 a piece....
    Feb 2007
    buffalo, ny
    blue
    bilstein it is but would i lose ride comfort with the addition of sub frame connectors
    Hamburg, Germany
    1998 Camaro Z28 A4
    Quote Originally Posted by Jumper View Post
    couldn't have put it better.
    no, i don't think you would compromise your ride comfort. of course, your car will be a little stiffer with the new shocks anyway. i'm gonna get sfcs as well.
    Iraq money well spent. TRY ME GT's Avatar
    Quantico Virginia
    Black on Black
    2000 Camaro SS M6
    Bilsteins. Thats what SLP put on my from the factory.
    Feb 2006
    pgh
    Does that mean you dont have to slow down and ease your car over a bump or dip?
    Feb 2006
    pgh
    You guys are saying they are stiffer than the SS DeCarbon shocks. Do you know if the Bilstein HD are 50/50 up and down, bump/rebound??
    Hamburg, Germany
    1998 Camaro Z28 A4
    Quote Originally Posted by rickssz View Post
    not as much, the shocks definitely prevent the car from diving that far. i don't scub the pavement with my air dam as often as before!
    Parkton MD
    2002 Z28
    My car is a 2002 Z-28 it has 12,000 miles on it, I did all of my suspension stuff one step at a time so I could see how it performed. The Bilstein shocks were first and they made the biggest improvement over the other mods, reduced body roll, helped the side step on bumps, firmed the ride a little but in a good way. Strano sway bars were next, and they reduced body roll, transitions thru turns was much better, the ride quality stayed about the same(firmer). The above two changes made the most improvements overall.
    UMI adj.PHB rod/poly ends, not much change in the car, the car no longer side steps on turns w/bumps. I next did 2pt SFC, and a STB, no big improvement, but the car felt tighter over smaller bumps/ripples. I have the stock 16 wheels with BFG KDW, I get compliments all the time on how the car rides and handles. I wish I would have gone with the Koni shocks, but Im totally satisfied with what I have.
    Member Runn_WS7's Avatar
    TranĂ¥s, Sweden
    1998 Trans Am WS7
    I love my konis
    www.ws7.se
    http://www.ls1.com/forums/showthread.php?t=1249
    Running on E85
    Twin Turbo Project Started
    Hello from Sweden.
    Junior Member Steve L's Avatar
    Feb 2007
    Arizona
    I have a '98 T/A and, like jumper, did my mods in smaller steps. I went with the 35mm front and 21mm rear sway bars first...that made a huge improvement in cornering and body roll. Then went with Eibach Pro kit and revalved Bilsteins the same time I installed SLP 3pt SFC and K2 3pt STB. I had the wheels aligned with 1.5 degrees negative camber in the front (back has .5 degrees negative camber from the lowering) and the car handles like it is on rails. I autocross mine with with some super-sticky tires and I couldn't be happier.
    Jun 2002
    Montreal, CANADA
    triple-black
    Quote Originally Posted by TRY ME GT View Post
    different shocks, though.
    Feb 2006
    pgh
    So it seems like the HD bilstein are stiffer than stock non SLP SS shocks especially on the rebound stroke.
    Member jmhvenom's Avatar
    Cincinnati, OH
    2002 Z28
    You will upgrade again in the future, might as well do it right the first time and get konis.
  1. Question: difference between bilstein hd and bilstein shocks
    By jonnyman in forum Suspension and Handling
    Last Post: 03-08-2013, 12:13 PM
  2. Bilstein shocks
    By benoh in forum Parts Wanted / Trade
    Last Post: 12-19-2006, 05:27 PM
  3. Kyb Agx Or Bilstein Shocks?????
    By BlackZ28629 in forum Suspension and Handling
    Last Post: 09-17-2006, 09:53 AM
  4. bilstein shocks
    By AnToN in forum Suspension and Handling
    Last Post: 03-14-2006, 07:49 PM
  5. Bilstein HD shocks vs SLP Bilstein Ultra shocks
    By Black Dragon in forum Suspension and Handling
    Last Post: 01-26-2006, 08:21 PM
