Results 1 to 20 of 21
    Junior Member harri_z28's Avatar
    Aug 2008
    pewter
    02' z28 camaro
    headers: anything i need to know?
    well i am done with the headers now!!! i started at 8:30 at night, and got done at 4:50 this morning! so my egr pipe wouldnt fit right, so i heated it, and bent it to fit. then i found out that putting spark plugs and wires back on was a bitch! and now i have dangling rear o2 sensors, do i unplug them, or just ziptie them up?
    im about to dig into my engine bay to put in my new headers, anything i need to know that might cause me some trouble? im new at this
    Last edited by harri_z28; 09-29-2008 at 01:58 AM. Reason: im done with the install
    Bragg NC
    Met. Sunset Orange
    01 SS
    Run a search and you will find everything ya need to know about your header swap... Just be patient and dont rush anything...
    J
    USMC Y2K_CAMARO's Avatar
    Rocky Point, NC
    PB Blaster is you friend, remember that, oh, and 10mm ratcheting wrenche
    Member BlackSS1's Avatar
    Lexington, NC
    2001 Camaro SS Vert
    Ditto the 10mm ratchet wrench! Also a lift and/or a buddy make the job much easier
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    Anti-seize for new spark plugs
    Di-electric grease for plug wires
    Lock tite for header bolts
    http://www.ls1.com/forums/showthread.php?t=90734
    Senior Member 01ws6er's Avatar
    The 717
    2001 Trash Can
    Patience, PB Blaster, and a friend should do the trick. Also. try taking off the coil packs for more room getting to your header bolts.
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    What kind of headers?
    Aug 2008
    pewter
    02' z28 camaro
    pacesetter lts for ls1
    Rocky Point, NC
    Quote Originally Posted by harri_z28 View Post
    Great, best budget headers IMO. I love mine
    Aug 2008
    pewter
    02' z28 camaro
    well after 2 weeks of back ordering, i finally got my headers in! got the y-pipe too. well monday im putting them on. i got 6 ton jack stands, pb blaster, im wondering about the gaskets, they are metal stock arent they? are they good to use? also ill need to take the coil packs off too wont i? just tryin to find out all the details before i trar into it all.
    SoDak
    White over Red
    1991 Suburban
    I used gm gaskets, that's what everyone recommends. I took the coil packs off the passengers side only.
    Lexington, NC
    2001 Camaro SS Vert
    The metal GM gaskets are like $25, definately the best quality. I installed headers with the coilpacks still on, but you will save your knuckles if you take them off :-).
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by BlackSS1 View Post
    +1 for the gm metal gaskets....ive never had a problem with tjem but I have changed many blownout paper gaskets
    in my Trans Am
    2000 Trans Am WS6
    yes def get NEW gm metal gaskets....
    Member WS6ICK2K's Avatar
    Jan 2008
    Pittsboro NC
    Metallic Blue
    2000 Trans Am WS6
    I had to loosen the motor mount on the driver side to get my pacesetters to fit. I agree with the others on the GM steel gaskets def worth the extra money. Goodluck
    Aug 2008
    pewter
    02' z28 camaro
    check out first post.
    Lexington, NC
    2001 Camaro SS Vert
    You can unplug the rear O2 sensors, the fronts of course go into the collector bungs. The lack of rears will cause a SES light until you get a tune or sims
    Aug 2008
    pewter
    02' z28 camaro
    yeah, i got that done now. but the driver side y-pipe is hitting the car and making that knocking noise, so i guess i need to get bump stops huh? how do they install? clamps?
    mercersburg pa
    hugger orange
    2004
    any good shops around your area? I'd use a sharpie pen and mark the pipe where its hitting, or even close to hitting, pop it off and have a shop with a bender tweak it alittle for you.
    if you take the pipe in with it marked good it should only cost a couple bucks to get them to do the tweaking to it
    Aug 2008
    pewter
    02' z28 camaro
    well i think its a little more then just a bend or a tweak... it seems like its almost all the way up against it. iv heard people using bump stops... is bending and tweaking a better option?
  1. mac mid headers or lt headers 2002 camaro with y pipe
    By chief98ls1 in forum Parts Wanted / Trade
    Last Post: 07-25-2012, 04:36 PM
  2. Question: Longtube headers or short headers?
    By 98maro in forum General Help
    Last Post: 03-01-2010, 05:25 AM
  3. which LT headers?? TOO MANY DAMN HEADERS TO CHOOSE FROM!
    By bad@ss mike in forum External Engine
    Last Post: 03-26-2006, 10:59 AM
  4. headers for sale? which headers should i buy?
    By wooten in forum External Engine
    Last Post: 02-19-2006, 11:18 AM
  5. Has Stainless Works Headers become the Top Headers of all?
    By Sunset T/A in forum External Engine
    Last Post: 12-04-2005, 06:54 AM
