Results 1 to 17 of 17
02-28-2010, 05:13 PM #1Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
Longtube headers or short headers?
Ih,I'm in the market to buy headers and I need Ideas. What's the diference between short and long headers? And it really add more hp?
Any diference on the fitment? I hear people complaint bout long headers. Cuz they dnt fit right. Thanks
02-28-2010, 05:16 PM #2Senior Member
- Apr 2008
- Madison, WI
Refer to the Headers sticky in the External Engine section:
The Complete (Hopefully) Header Thread
02-28-2010, 05:22 PM #3
Do it right and go with the long tubes,shorties are basically replacement exhaust manifolds IMHO.
If you go the long tube route,your probably going to end up replacing the convertors and y-pipe as well...My advice would be to buy the whole thing as a kit...headers,y-pipe-high flow or no convertors...It will be worth it in the end.
02-28-2010, 05:22 PM #4Senior Member
- Feb 2010
That page helps alot thanks
02-28-2010, 05:30 PM #5Senior Member
- Apr 2008
- Madison, WI
Make sure you figure in the cost of 2 new GM exhaust manifold gaskets, 2 new Bosch #13111 O2 sensors, new header bolts (somewhat optional depending on the condition of your current bolts), and a tune. The tune is needed to delete the rear O2 sensors and adjust the air fuel ratios. These cars tend to run a little rich after a header swap.
02-28-2010, 05:35 PM #6Senior Member
- Feb 2010
I like long headers n I think they work better than short ones. So the long will fit with no problems?
02-28-2010, 05:38 PM #7Senior Member
- Feb 2010
I think I'm gonna use the same ones for now. What headers would you recomend me? What brand. Thanks
02-28-2010, 05:41 PM #8
i've got shorties on my ss they fit great. although I want long tubes, the shorties were already on it when i purchased it.
02-28-2010, 05:42 PM #9Senior Member
- Apr 2008
- Madison, WI
Most will fit just fine. Some require a little denting on the header tubes and/or y pipe. The top three recommended brands seem to be:
American Racing Header (ARH)
Kooks
Pacesetter
But there are plenty of others to choice from that fit very well and perform great. Your best bet is to read read and read all the header threads you can on this site. Then find a set of headers you like and research them. Thats what did and I just ordered Kooks headers this morning!!
Oh and since you're in California, you'll need to make sure you research whats needed to pass emission testing.
02-28-2010, 05:59 PM #10Senior Member
- Feb 2010
Yeah I need the ones with the egr connection thing. I was lookin at some hooker ones bt they dnt come withe egr so it's gettin kinda hard to find em. And also I seen many diferent brans on eBay. Bt I dnt knw if I should get em there cuz they go from $80 to $600 and I dnt kne if those are good.
And those it feel any diference between short n long
02-28-2010, 06:05 PM #11Senior Member
- Apr 2008
- Madison, WI
yeah you probably need EGR and AIR connections plus catted y pipe and keep the rear 02 sensors.
02-28-2010, 06:13 PM #12Senior Member
- Feb 2010
So it would be better if I buy the whole kit then? Headers y pipe and all that stuff for a better fit. I was thinkin bout remove the caTs but I'm sure I could get a ticket for that or my car could get impounded. Plus wnt be smog legal.
Do you have short or long headers on yours?
02-28-2010, 06:27 PM #13Just a farmboy
- Jun 2007
- Montpelier, VA
Pewter- 2000 Pontiac Trans Am
make sure you start soaking all the header bolts with pb blaster, wd40, or some other break free. go slowly, i broke 1 bolt off and found another already broken off. seems to me a lot of people have had a problem with the drivers side front most bolt. ive seen 4 or 5 posts of people breaking that one, including me. the bolt that was already broke off was the drivers side far back bolt.
02-28-2010, 06:42 PM #14Senior Member
- Feb 2010
Oh ok. I look out for that. Thanks for the heads up.
Or if I see it's too hard I'll just take it to the shop. N the charge $250 jst to install em
02-28-2010, 06:56 PM #15
The only problem I had was the driver's side header was rubbing on the upper steering shaft bolt,easily fixed by grinding a little bit off the bolt head.
I've also heard of some guys with the slp longtubes having issues with the oil pan drain plug being too close to the driver's side header to remove.I know on mine it is close but not a problem.
02-28-2010, 09:40 PM #16Senior Member
- Feb 2010
And what did u do to fix that?
03-01-2010, 05:25 AM #17Just a farmboy
- Jun 2007
- Montpelier, VA
as to the steering wheel bolt, you take a grinder to it.
Question: Longtube headers/
By 98maro in forum External EngineReplies: 26Last Post: 07-11-2010, 09:09 AM -
WTB Longtube Headers
By 5abivt in forum Parts Wanted / TradeReplies: 0Last Post: 10-11-2009, 10:33 AM -
WTB: Longtube Headers
By 98camaro in forum Parts Wanted / TradeReplies: 0Last Post: 08-14-2007, 04:30 PM -
obx longtube headers
By bigjpyn in forum Parts For Sale / TradeReplies: 1Last Post: 05-10-2007, 11:40 PM -
Longtube Headers
By morocotopo in forum External EngineReplies: 0Last Post: 10-20-2005, 09:41 PM
