Results 1 to 11 of 11
Thread: Long Block vs Short Block
09-02-2008, 10:44 PM #1Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
What's the difference?
Which one (or both) wouild fit in my Trans Am?
09-02-2008, 11:18 PM #2Senior Member
- Sep 2007
- Denton, Texas soon Lafayette, Louisiana
Blue- 2002 Z28 Camaro M6
It can vary between places, but normally when I think short and long blocks the difference is heads. Long blocks have heads and short blocks do not. Otherwise they can be almost identical. If you are going to get a long block just make sure you read carefully all that it comes with since the term can vary (should also do the same for short blocks).
09-02-2008, 11:23 PM #3Sold: LS1 '85 El Camino
- Dec 2005
- Laurel, Maryland
Oh, so there is no length difference, it's a term referring to whether or not the product has heads or not, right?
09-02-2008, 11:27 PM #4
09-03-2008, 01:03 PM #5Member
- Feb 2006
- MD
Shortblock would consist of the block, crank, rods and pistons (bearing and rings etc as well)
A longblock would consist of a shortblock with cylinder heads, camshaft and complete valvetrain. Rarely they might come with items like a crank pulley, timing set, water pump, valve covers, and other various items.
Short vs long has nothing to do with physical dimension.
Where in Laurel are you? Never see you around...
09-03-2008, 04:44 PM #6
09-05-2008, 02:28 PM #7Member
- Feb 2006
- MD
09-05-2008, 11:15 PM #8
09-06-2008, 06:40 PM #9
Long block are 7 feet longer. They only fit if you take the passenger seat out.
JK
09-06-2008, 07:19 PM #10
09-08-2008, 09:54 AM #11COTM July '09
- Jun 2008
- Annapolis, MD
BLK/BLK w/CGM Stripes- 2010 Camaro 2SS/M6
that's a REALLY LONG block!
short block vs long block
By askkmb in forum Internal EngineReplies: 3Last Post: 12-15-2012, 06:52 AM -
Question: short block vs long block
By fbodyNATION in forum External EngineReplies: 4Last Post: 01-25-2011, 08:25 PM -
long block s. short block
By peteSS in forum Internal EngineReplies: 3Last Post: 01-13-2008, 11:11 PM -
WTB: 98-02 LS1 long block or short block
By QucikSilver in forum Parts Wanted / TradeReplies: 1Last Post: 07-10-2006, 10:17 PM -
long block or short block ?
By themack56 in forum Camaro / SSReplies: 8Last Post: 02-12-2006, 05:25 PM
