    **Te@M fBoDy** fbodyNATION's Avatar
    Nov 2010
    The Woodlands,Texas...N.O.
    Pewter Metallic
    2000 Pontiac Trans Am WS6
    short block vs long block
    i just wanted to ask a simple question how do you indentify if your LS engine is a short block or long block? i just heard ppl saying long block,short block & so on,i thought all LS engines were short blocks because they were referred to as the GM Small block engine
    Senior Member redbird555's Avatar
    Mar 2009
    pompano beach florida
    2002 Camaro Z/28 Pewter
    lol that has nothing to do with it being a small block or gm engine for that matter a short block is an engine that hass just the block and rotating assembly.... a long block is that plus the cam valvetrain and heads
    Member youngrigo's Avatar
    Nov 2010
    Bay Area, CA
    2000 SS
    short block is just the bottom end from the pistons down....
    Long block includes everything the short block does plus the heads, cam, intake everything....
    Nov 2010
    Pewter Metallic
    oh ok thanx guys
    Feb 2007
    San Diego, CA
    2002 Z28 A4 NBM
    Sadly now demodded :(
    Long block does not include intake...
    Here's what you can expect:
    Short block: Block with rotating assembly (pistons and crank). May or may not include cam. May or may not include balancer and flex plate or flywheel.
    Long block: Short block plus heads and cam plus valvetrain. May or may not include intake and various pieces on the fuel system (carb and or injectors). May or may not include balancer and flexplate or flywheel.
    Complete assembly: All of the above plus intake and carb and/or injectors. Even then it still may not include balancer and flex plate or flywheel. Should but may or may not include the throttle body if fuel injection.
    None of the above will include the accesory's and drives.
    67 Camaro: K-K + 797-z (look it up), 454/Th400/4.10 12-bolt = 6mpg, PS/PDB/PW tilt, tach, gauges...
    Carbon footprint? CLOWN SHOE!
  1. short block vs long block
    By askkmb in forum Internal Engine
    Last Post: 12-15-2012, 05:52 AM
  2. Long Block vs Short Block
    By ls1camino in forum Internal Engine
    Last Post: 09-08-2008, 08:54 AM
  3. long block s. short block
    By peteSS in forum Internal Engine
    Last Post: 01-13-2008, 10:11 PM
  4. WTB: 98-02 LS1 long block or short block
    By QucikSilver in forum Parts Wanted / Trade
    Last Post: 07-10-2006, 09:17 PM
  5. long block or short block ?
    By themack56 in forum Camaro / SS
    Last Post: 02-12-2006, 04:25 PM
