Thread: oil level sensor
08-26-2008, 08:03 AM #1
oil level sensor
my low oil light has been on for two weeks. the oil level is fine. now the car wont run when it gets warm. i just put a brand new distributor and coil. will that sensor make my car do that.
08-26-2008, 10:58 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
Don't think so, it doesn't on the LS1 cars - just comes on when it thinks you're about 2 quarts low. Just a level sensor similar to the low coolant. If your SES is on I'd get any codes read.
08-27-2008, 06:04 AM #3
if the oil is full wouldnt it make since that the oil level sensor is bad. i have a lt1. i was told that if that sensor was bad that the car would not run. but i Dont know.i will find out this weekend when i put a new sensor in.
08-30-2008, 02:46 PM #4
I changed it out and reset the code. Car ran good for about 40 mins then died again. So the oil level sensor is not the problem. when it dies it will start back and run only if you let it idle. As soon as you touch the throttle it will die. Any ideas on what will make it do that. I have a 95 with a kt1. Just replaced the distributor and coil about 2 weeks ago. Could the icm be bab?
08-30-2008, 03:16 PM #5Senior Member
- Jul 2005
- Jacksonville, FL
Didn't think the sensor was the problem. Did you scan for any codes or just reset the PCM? OBDI code(s) if any, will help nail down the problem.
08-31-2008, 01:58 PM #6
the ses is not on. i had a buddy try and read the pcm and came back with no codes. the icm is over heating.i can take it off and let it cool down and put it back on and the car will run fine. is the icm going bad.
08-31-2008, 02:22 PM #7Impounded
- May 2008
- Verdigris, OK
NBM- 99 z28
Coolant level sensor
By fury78 in forum General HelpReplies: 13Last Post: 09-12-2009, 06:01 AM -
oil level sensor?
By joejenkinsglass in forum General HelpReplies: 5Last Post: 01-29-2008, 04:39 AM -
oil level sensor
By 96 ta in forum LT1Replies: 1Last Post: 12-09-2007, 12:29 PM -
where is the Coolant Level Sensor?
By SexyTransAm in forum LT1Replies: 7Last Post: 10-03-2007, 07:48 PM -
Where is the Coolent Level Sensor on 98 Z28 ?
By samualt in forum General HelpReplies: 1Last Post: 06-01-2006, 01:58 AM
