Results 1 to 14 of 14
    Junior Member fury78's Avatar
    Apr 2009
    Bilbao, Basque Country
    1999 Camaro Z28, 6 speed
    Coolant level sensor
    Well, last April the "low coolant light" lighted. The level was perfect, so I ordered a new sensor.
    After 3 months, and less than 3000 miles, the light is on again. I have checked the level on the radiator and it is ok, and the temperature of the car while running is like always.
    Is it usual that this sensor fails so fast ???
    My car is a ´99 Z28.
    jacksonville nc
    1995/2002 camaro z28's
    normal, also make sure youve got all the air out of the system, if that doesnt work just unplug it and check the level from time to time
    Member NoscamaroSS's Avatar
    Durant, Okla
    2002 Camaro
    ^^x2
    02 Camaro
    PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
    *Old Time* 10.90@ 125mph
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    If you bought a replacement from someone other than GM the damn things are made in mexico, china, indonesa, ect.. Very common for that crap to fail but most of the time they work for a couple of years.
    Arizona
    Quote Originally Posted by JaycenK View Post
    Yep, very true. I've found alot of the GM stuff made in Mexico too,,,what a shame...Also keeping the antifreeze fresh is a big help too. If it starts to look nasty it's probably too late.
    Apr 2009
    Thanks for your answer. I bought it from rockauto and the warranty has expired ( 90 days ). Do you know any web where buy an original replacement ?
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Quote Originally Posted by fury78 View Post
    Gm Parts Direct dot com
    Member 99'CajunFirehawk157's Avatar
    39466 USA
    Bright Red
    99 Firehawk #157 Roadster
    FWIW, last time my light came on, since my car is a garage queen, I took the old sensor out and just cleaned all the gunk off of it, (its original 1999) and even since the coolant was drained and flushed regularly the sensor was still gunked up, sure enough when I put it back in the light went off, YMMV.
    Regards,
    Todd
    #cajunhotrodder on instagram
    Arizona
    Ya coolant gets more corrosive over time, and really play havic on those switches. Which is why it's imprortant to keep tabs on coolant condition. It can be tested to see how acidic it is and at what point it should be changed.
    I generally flush and change mine every year but I'm anal about it. I don't care if the bottle says it's a 5 year antifreeze or not.
    Apr 2009
    Thanks for all your answers. So, I will change the coolant and buy a new sensor....
    Member TA98's Avatar
    Mar 2009
    Maryland
    Where is the sensor located
    Apr 2009
    Quote Originally Posted by T/A98 View Post
    In the radiator, upper part, right side ( passenger side )
    Mar 2009
    Maryland
    Alright, thanks
    I would flush that coolant and just try to clean your current sensor and see if that works. Not sure if you've ever done a flush/fill on your coolant but if you haven't then that coolant is 10 years old....time for some new.
  1. Question: Coolant reservoir level goind down but no physical leak?
    By JayTA98 in forum General Help
    Last Post: 01-28-2014, 02:41 PM
  2. 99 f-body coolant level sensor removal; HOW TO?
    By 99'CajunFirehawk157 in forum General Help
    Last Post: 01-06-2008, 10:14 AM
  3. where is the Coolant Level Sensor?
    By SexyTransAm in forum LT1
    Last Post: 10-03-2007, 07:48 PM
  4. Coolant light...coolant level full.
    By SR71 in forum General Help
    Last Post: 01-08-2007, 09:35 AM
  5. Coolant Level Light 1998 T/a
    By 332camarob4c in forum General Help
    Last Post: 08-23-2006, 03:28 PM
