01-06-2008, 07:59 AM #1
99 f-body coolant level sensor removal; HOW TO?
Normally these sensors are round and you put a socket over them to remove, mine is square like a small circuit board box, how do you remove it?
Regards,
Todd
#cajunhotrodder on instagram
01-06-2008, 09:07 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
It's not in my helms since they took them off our cars in 2000 - probably similar to the LT1 sensor though - http://shbox.com/1/low_coolant2.jpg
01-06-2008, 10:09 AM #3Junior Member
- Sep 2005
- ky
Black- 99 camaro
The easy way to fix the low coolent sensor is just unplug the it and the light will never come on again.
01-06-2008, 10:14 AM #4
In the pic on http://shbox.com/1/low_coolant2.jpg, its really hard to tell the clip is one piece and it comes off in the direction of the battery, but it is and it does...I was able to just jam a rag inside of the hole and very little fluid was lost, then I just took the sensor and cleaned it good, stuck it back in and no more light. Once you take the battery out it is a breeze, maybe 15 mins tops, thanks guys!
YMMV.
Question: Coolant reservoir level goind down but no physical leak?
By JayTA98 in forum General HelpReplies: 10Last Post: 01-28-2014, 02:41 PM -
Coolant level sensor
By fury78 in forum General HelpReplies: 13Last Post: 09-12-2009, 06:01 AM -
where is the Coolant Level Sensor?
By SexyTransAm in forum LT1Replies: 7Last Post: 10-03-2007, 07:48 PM -
Coolant light...coolant level full.
By SR71 in forum General HelpReplies: 4Last Post: 01-08-2007, 09:35 AM -
Coolant Level Light 1998 T/a
By 332camarob4c in forum General HelpReplies: 3Last Post: 08-23-2006, 03:28 PM
